AWD Problem
This topic is in the MVS Volvo Repair Database » Angle Gear & Transfer Case Terminology, Explanation
Stravlr
Year and Model: 2004 XC90 T6
Post by Stravlr »
netasp wrote:I got the car back from the dealer, both the angle gear and the sleeve and the o-ring seal were replaced along with some sensors, still no AWD as they told me I need an A.O.C Pump ($384.00) + couple hours labour, when asked about how sure they were, they said 90% they are claiming the DEM is working fine
Does anyone know how the DEM works? How do you usually know your DEM is good or not?
Thanks
Stravlr
Post by Stravlr »
Also the A.O.C (Active On demand Coupling) Pump is typically referred to the Haldex pump, There is a bunch of info on the forums about them, its not a XC90 specific unit.
bguzz
Year and Model: 1998 S70 N.A.
Post by bguzz »
jimmy57 wrote: The angle gear needs to have new synthetic 75W140 gear oil put in it when it is installed.
Are you sure about the 75W140? I think it might be synthetic 75W90 GL5.
2008 XC90 3.2L - 134k
2006 Ford F150 4x4 124K
Sold 98 S70 N.A.@418K-still ran great!
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Car came from factory with 75W90, but later Volvo "updated" it to 75W140.
Either fluid is fine.
bguzz
Post by bguzz »
ooh, I just bought some redline 75W90 GL5...i'm about to change my angle gear fluid (as much of it as I can)...should I be opting for the 75W140 instead?
Post by cn90 »
I'd not worry about it.
I put Redline 75W90 in my transfer case.
Post by cn90 »
Old post but I need to ask the "sleeve" gurus...
2005 XC90 with 90K miles.
Put in Drive..."raoooo" noise for a few sec. Put back in P, no noise.
Put in R, "raoooo" noise for a few sec.
Now it is all quiet.
Questions re Angle Gear Sleeve...
In the early phase of failure, does it make any noise?
Post by cn90 »
Re: Testing AWD system.
I don't have a lift to test it but here you go the ghetto way. It was snowing, so I brought the XC90 on cul-de-sac with a hill (about 3-4 degree slope), it has about 1-2 inches of snow.
I told my 14-year-old son to stay on the sidewalk and watch the REAR wheels while I go up the hill.
I specifically ask him "Do the REAR wheels spin like crazy?".
His answer is "Only the FRONT wheels spin like crazy, not the REAR".
So there you go, my angle gear sleeve (vs AOC) is kaput. Personally, I don't mind FWD (I have driven many many FWD cars in my life) because my vehicle:
- Has snow tires in winter.
- I may save some gas mileage (FWD vs AWD fuel consumption).
- Car is quiet, no grinding sound.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
You're going UP a hill when most weight is transferred to REAR wheels and you expect them to spin? The Haldex only pushes 25% of power to the rear wheels MAXIMUM.
Don't really know if this test is providing the answer you think it has.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
I would go up the hill in "R" reverse while there is snow on the ground to verify assumption.
