You think that will help the issue, any idea why the car works ok when cold, the first few minutes? Shouldn't it be the other way around if fluid is low? Just wondering....JDS60R wrote:Yes - It sounds like you are a little low on fluid as you reported you are getting the cold range indicated when the fluid is hot.
Please add some fluid so that it is in the hot range when hot.
Also, if adding won't help, do you recommend any additive?
It's awesome to be on this forum, I can tell you guys know tons about Volvos
