Timing belt failure log MTBF
Has thanked: 292 times
Been thanked: 765 times
Re: Timing belt failure log
Post by erikv11 »
Y'all are not paying much attention to the thread ... OP only wants to know about failures.
abscate wrote:The goal of this thread is to get > 30 logs of timing belt failures with mileage to see if we can get an idea of how long these parts last.
Entry format
First line: year, model, engine, year replaced, mileage replaced,
Second line - mechanical commentary on what failed, if anything
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
abscate wrote:Using replacements before failure data obviously gives a lower bound to MTBF vs actual MTBF, but for the purpose of this study, that will suffice.
It sounds like OP is also interested in replacement w/o failures.
Has thanked: 1497 times
Been thanked: 3809 times
Clarification - all data is useful - even ...my car has run for 80k on original timing belt - never replaced, never failed. Such a data point will pull down the MTBF lower bound, but thats ok.
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
abscate wrote:Clarification - all data is useful - even ...my car has run for 80k on original timing belt - never replaced, never failed. Such a data point will pull down the MTBF lower bound, but thats ok.
Of course you can include change intervals before failure, but if you do your results won't say anything at all about MTBF. All you will have is is mean time between belt changes.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
backfoot100
Year and Model: 98 S70 T5, 07 C70 T5
Post by backfoot100 »
OP's requested data on my TB changes.
'98 S70 T5. TB tensioner is hyd.
5/03; 40K, purchased from original owners
11/03; 50K, 1st TB. I mistakenly thought these were 50K intervals. My bad.
6/06; 121K, 2nd TB
2/08; 179K, 3rd TB, pulleys, tensioner, water pump. This change was only a 60K interval again. I was starting to freak out that the OEM pulleys, water pump and tensioner were still in there and figured discretion was the better part of valor.
2/10; 250K, 4th TB, pulleys, tensioner
4/12; 324K, 5th TB, pulleys, tensioner, water pump
Currently at 357K. Every TB changed looked virtually unworn. Started changing tensioner and pulleys at every change just for piece of mind. Water pumps every other change. Always reading about the horror stories of catastrophic failures which is the reason for this thread right? I like to err on the side of caution.
Exactly. For someone in your shoes, keeping car indefinitely, your err on the conservative side. You also learn to do it yourself and save 4000 USD in the bargain.
Getting a lower bound and standard deviation on the MTBF is useful to the person who buys a 100k Volvo project car, and wants another 20k out of it, for example. WIth this info, you can gauge how much of a risk you are taking running existing TB.
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
The predictive validity of this analysis will be suspect due to huge random variation in other factors related to how hard a car was driven, maintenance items, whether it was used for towing, possibly seal leakage and maybe belt manufacturer. Also, as others have pointed out, how long it was out of service could affect longevity (failure data could help validate or discredit that theory).
It might be quite easy to control for some of those factors simply by asking for a little more information and ranking answers on a scale of 1 - 5 for the respective factors—then of course including all that data in the research model. Those scaled data would still be subjective but could be somewhat helpful in making the predictive model a little more factual, rather than loosely conjectural.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
JanuWan: I promise you, after 155,000 miles, everything wasn't in perfect condition. I'd be afraid to try to push rollers past 140,000. I seriously doubt they will go 210,000. Those things had to be loose.
JimBee: I don't think it matters how hard you drive these cars. The belt, rollers and water pump will go 70,000 under any legal circumstance. Even if you are able to cruise at 110+ mph daily the rollers will make noise before failing.
If people would use their senses and listen to their car complain and do something about it before it fails, and follow maintenance schedules for stuff that clearly has time change intervals, a broken timing belt would be a very rare occurrence. Matter of fact, I'm sure there are more cars blowing head gaskets than loosing timing belts. Only because the owners are playing "engine roulette" by adding coolant daily/weekly. I pull every timing belt cover off every Volvo I see in the JY and I'd say that less than 15% of them are there due to timing belt failures.
hansenjg
Year and Model: 2011 XC60 3.2
Post by hansenjg »
If you are still looking for data, here is mine for my 2000 C70 Ragtop. Bought in 2005 with only 20K on it. Changed OE belt at 125K miles in 2010. Also replaced tensioner and water pump at that time. Should not have replaced pump I think. 65,000 miles later (after a fairly long time of losing just a little coolant constantly) the water pump seized up and took the timing belt off. Engine destroyed. When I opened it up to see what I could do with it, the timing belt was still in pretty good condition except for the cuts and scrapes from when it got thrown off. Don't use cheap water pumps and don't replace them unless necessary!
John
2004 C70 Ragtop w/2.4L LPT 65K miles (wife dd)
2003 XC 70 with 2.5L Turbo, 195K miles (my dd)
Parts Car: 2000 C70 Ragtop w/2.3L Turbo, died at 200K miles (water pump siezed. took out timing belt)
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Post by mecheng »
Which statistical software are you using? Are you using Weibull statistical analysis?
I can't give you a failure point but:
My 850 had the belt changed at 70,000 miles and it looked as close to perfect as possible. Only the timing belt was changed. The car has 100,000 miles and everything is perfect: rollers, tensioner, WP.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
