Starter Not Disengage 1997 850 T5 RESOLVED, wiring wrong
Has thanked: 1611 times
Been thanked: 4072 times
please confirm success after you have rewired so we can close thread
drzaeis
Year and Model: 1997
Has thanked: 3 times
Post by drzaeis »
Great success...it was wired incorrectly, both leads go on the outboard stud...not going to use that mechanic again. he swears the two big wires were on separate terminals when it came off..
He can swear all he wants. They weren't. With your nice pictures documenting the mistake, I would nicely ask him if you should expect any further electrical damage as a consequence and how should you proceed if that happens?
Then forget about it and move forward.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
drzaeis wrote:Great success...it was wired incorrectly, both leads go on the outboard stud...
I understand that you fixed the problem, but could you post an updated photo, take a few photos and post them, as I am curious how you did it!
Now I am confused...
- On the outboard stud, as jimmy57 said, there is supposed to be RED cable only.
- If you attach the BROWN Cable (supposed to be some kind of ground) to the outboard, you will probably short the battery?
- See the photo below:
* 1st image is yours, even though the BROWN wire is not supposed to be there, it is ground anyway.
* 2nd image is the factory setup with ground strap btw solenoid and starter motor.
* 3rd image is the Volvo 850 Starter circuit.
Maybe some gurus can explain the mystery?
YELLOW #1 is ground, #2 is the green wire (which is controlled by the ignition switch), #3 is the RED Cable (always hot).
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The bare wire out of starter case is not a ground, it is the + wire to the pair of + brushes, the ground brushes are connected internally to the motor case to be grounded. Look at the black rubber cone shaped grommet where the braided lead enters motor case in the photo. A ground lead would need no insulation from the motor case. If you survey a number of different makes of starters you will find that lead bare like that. My two John Deeres, my two Ford diesel PU's, and the Komatsu dozer I rented all have bare braided or a solid copper strip that goes from switched solenoid main terminal into motor case.
Color codes are not stringently adhered to and some insulation stains or gets color bleed. I think the alt to battery cable post at starter on my 98 XC70 was brown.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
A picture really is worth a thousand words.
I never would have guessed this one...
Glad you got it fixed.
When someone wires incorrectly it gets ugly real fast, especially unfused battery cables .
I can almost sense the really knowledgeable people here cringe when we get a " I have electrical problems" and then post a picture of some totally Charlie Foxtrot wiring job
Post by cn90 »
This is strictly for academic discussion.....the normal process is:
1. Crank the starter, current flows to GREEN wire, activating the Solenoid.
2. The Solenoid is moved (BLUE arrows), and 2 things happen simutaneously:
- engaging the clutch to flywheel
- sending power to the motor (RED arrow current flows from "2" to "3")
* Even with the 1st photo posted by the original poster... The BROWN Cable (which I assume is ground) is a mystery. I have never seen the big Brown cable in the vicinity of the starter motor.
* Now if the BROWN Cable was attached to the inboard post, why didn't he see sparks flying when he cranked the starter?
You cant use colour coding to ascertain wiring function reliably, especially on big cables which have likely been replaced. It looks to me like Volvo chooses to make the main primary connection from the alternator output by mating this cable to the battery cable connection at the starter, which makes sense.
Brown does not mean ground in this case, but perhaps the only colour cable the shop had with the previous owner replaced the cable..
jimmy57
Post by jimmy57 »
Volvo and other manufacturers do not adhere to red=positive, brown or black=negative. Volvo used blue ground cables for years. Wires in a multi lead harness need color code. Large cables with lugs that fit onto posts and run by themselves or in a sleeve with only a few wires do not need color coding. That alternator to starter 50 stud cable is no more than 18 inches, probably 12-14 inches long. No need to worry about color when it will need no tracing by color in manufacturer or normal service.
