1998 GLT V70 Hard start below 30deg/studders SOLVED
BlackThunder
Year and Model: 1997 850
Has thanked: 6 times
Been thanked: 3 times
Post by BlackThunder »
So I've just gotten this code. Can it be ANYWHERE in the vacuum system that could be causing this problem? I was working on my ABS module and I think I may have broken one of the purple lines that is coming off of the air box. But that's not part of the vacuum system is it?
1997 Volvo 850 N/A
Thanks,
Dustin
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
1997 Volvo 850 N/A
Thanks,
Dustin
I also broke the purple but in two spots and just used a piece of rubber vacuum hose to join them together.
BlackThunder
Ok, thanks. I"ll give it a try. I'll have to stop at Auto zone and get some hose. I'm wondering if that is causing my "mixture too rich" code.
Dustin
Dustin
2013 Volvo C30 T5
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
BlackThunder wrote:Ok, thanks. I"ll give it a try. I'll have to stop at Auto zone and get some hose. I'm wondering if that is causing my "mixture too rich" code.
"mixture too rich" code + broken vac hose, almost certainly yes.
Also -> Amazon link
fayborja
Year and Model: V70 1990
Post by fayborja »
Hello!
I am having a similar issue. I live in Oregon so with the colder whether I am experiencing a hard start. The only difference is my car doesn't start at all. It used to crank, turn on for a min, then die. Now it just cranks won't start up. I changed the thermostat and temperature sensor but I did not disconnect the battery during the job. Codes read: P0243, P0455. I recently paid a mechanic to look at it and he said it was the fuel pump and filer. Otherwise, my car runs fine when it is warm out! Please any help would be appreciated.
fayborja
Post by fayborja »
1998 Volvo v70 is what I own...Thank you!
-Fay
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
fayborja wrote:Hello!
Unplug the connector the the mass airflow sensor, attempt starting the engine. If it start up and idles fine, even responds to the gas pedal, replace the mass airflow sensor.
'98 S70 T5
2016 Chevy Cruze Premier
fayborja
Post by fayborja »
Thank you so much! Will give it a try in a couple hours and get back to you!
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Post by stephansvolvo »
fayborja wrote:Thank you so much! Will give it a try in a couple hours and get back to you!
I just replaced the fuel pump and it didn't make a difference. Pull your fuel pump relay, take it in the house for about an hour and then put it back in. Start the car. I did this after replacing the fuel pump and it started up. If it starts and stays running like mine did. I found the part on amazon for $43. A lot cheaper than the already spent 220!
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
stephansvolvo
Check this out
https://www.matthewsvolvosite.com/forums ... =1&t=60605
Stephan
98 S70 GLT
73 IH Scout ii
