1998 V70 No Heat, engine overheating
volvooh
- Year and Model: '98 S70, '05&'08 V70
- Been thanked: 4 times
Re: 1998 V70 No Heat, engine overheating
Thanks all...my indie said the same thing to me. When I flushed it with distilled water, it likely left enough water in to throw the mix off. With it being so cold I can't work on it...she's all thawed and I am $100 dollars poorer.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Be very careful when choosing coolant.
Look at the specific weight of coolant in the container. For example pure coolant has over 1000g of ethylene glycol per litre (in the U.S, Liberia and Burma where the older measurements are used this may be stated as 16 oz per quart)
In this case mix the coolant with distilled water at 50/50 concentration.
If the ethylene glycol is less than stated above you're using a pre-mix coolant which in most cases is mixed incorrectly for Volvos.
Some pre-mixed coolants are arranged at 50/50 which would be around 500g or 8oz of ethylene glycol per litre/quart.
It's all in the detail
- Has thanked: 1505 times
- Been thanked: 3818 times
That's just mean, Mike. It's the United States, Brunei, and North and South Yemen using God Given units.
precopster
You may get your info from a higher source, Steve
- 11 Replies
- 1386 Views
Last post by NYCKID221
- 341 Views
Last post by Flyingdutchman
