98 s70 no start intermittently.MVSOLVED, dirty IAC
Has thanked: 1501 times
Been thanked: 3812 times
Re: 98 s70 no start intermittently.MVSOLVED, dirty IAC
You still have a no crank issue, right ? Resolve that first...ignition switch, grounds, battery cable
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
mecheng wrote:Is there a specification listed somewhere, I'm definetly above 850 rpm.
Do you have a check engine light on?
If mpg is good and if the car runs ok,i guess that you have a little vacuum leak somewhere.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
Or a big vacuum leak that isn't visible? I had similar symptoms on my '96 850. It had been running but stalling at intersections. One day, it started but died as I pulled away from the curb. After investigating the fuel pressure, etc., finally discovered the large corrugated air intake hose was blown out on the back side. The membrane that covers the wire winding is quite thin. Replacing that brought it back to normal.
