1996 850 Wagon Service Light On Topic is solved
- Has thanked: 312 times
- Been thanked: 818 times
You may hear other opinions but for the transmission I use whatever Dexron is the cheapest and just pay attention to the service interval. Supertech (yep, Walmart brand) or whatever they have at Costco or Sam's club, usually. People who drive these cars hard like Mobil 1. You definitely can't go wrong with the Maxlife.
PeteB
- Has thanked: 57 times
- Been thanked: 11 times
I went to buy some Valvoline Maxlife ATF and it now says full synthetic - I wonder how different it really is? It is on sale for about $11 a gallon there!
It looks like they might have just changed the marketing for it since:
" Here in the US, oil manufacturers are allowed to call highly-refined petroleum-based (Group III) oil a synthetic"
http://www.saabcentral.com/forums/showp ... ostcount=4
PeteB
It is very cold here into the teens at night maybe single digits tonight and my
son got a CEL, had it tested code P0410. This is a SAS problem?
Do we do the diode mod or is there anything simple we should check first?
Is this urgent, other than not being able to see other codes? Does the ECU run
in some sort of degraded limp mode just due to SAS with the light on?
- Year and Model: Many Volvos
- Been thanked: 76 times
The P0410 is a SAS code and it doesn't put the car into any kind of limp mode if that is all it is. The diode trick will end it forever.
PeteB
Thanks, but if it was something simple like a relay is there a procedure online to get it working again?Ozark Lee wrote:The P0410 is a SAS code and it doesn't put the car into any kind of limp mode if that is all it is. The diode trick will end it forever.
Is the air pump electric or is it the solenoid that it operated by the relay?
Found this, looks like the air pump is electric:
http://volvospeed.com/vs_forum/topic/14 ... ?p=1882117
Correct, the air pump is electric. P0410 is strictly a nuisance code, won't affect operation at all.
Eight times out of ten the light comes on because the SAS valve has failed, condensation has collected in the air pump, and filled it with water so that it eventually stops working. So to fix it you need to get a new SAS valve and a new pump. Or a diode. The other two times there is a vacuum leak somewhere. Diode fixes that too.
Here is the definitive diode link over at Volvospeed, there is probably a good one here too http://volvospeed.com/vs_forum/topic/14 ... with-pics/
- Has thanked: 1611 times
- Been thanked: 4075 times
Pete...in your case you probably collected condensation which froze.
Next thaw might clear up,the problem and reset the code
PeteB
Car has been running well.
Front tires are nearly bald on the outside. It had four relatively new tires when we got
it, maybe 2 years old but with probably less than 5000 miles on them and I guessed that
they got an alignment when they bought them. I think that they are from Town Fair tire
who does require an alignment IIRC.
I guess we have to check for tie rod ends, etc. before we go in for 2 new tires and an
alignment. Anything else to check while we're under there?
- 1987 Views
Last post by precopster
- 1325 Views
Last post by Sommerfeldt
- 2317 Views
Last post by oragex
- 1978 Views
Last post by psamanni
- 4811 Views
