ETS light without symptoms, yellow sticker
taxi
Year and Model: V70 2000
Post by taxi »
I hope you mixed something up: 9520: accelerator pedal? It isn't brake pedal sensor, right?
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I looked up ECM-9520 and the web search indicated it was the brake pedal position sensor.
taxi
Post by taxi »
Developments:
On two separate occasions, when I start the car, it revs high, into the red area, and the ETS-light comes on.
Haven't checked codes again, but I found a cheap replacement pedal, including sensors. I will tell you how it goes :D
taxi
Post by taxi »
It went perfectly! For a short test run. The ETS light went off on its own also.
If I don't write here again, it means it continued to work.
Thank you for getting involved, Mike!
taxi
Post by taxi »
Well, it's still working, so I consider this solved!
precopster
This is MVS' first pedal problem with ETM that I can recall. Thanks for sharing !!
taxi
Post by taxi »
I think I have the explanation: the pedal unit is marked "Hella" and "Made in Germany" :D
forumoto
Year and Model: XC90
Has thanked: 1 time
Post by forumoto »
I have 2002 V70 T5 gas/petrol with code of ecm9520 the bcm cannot communicate to the scan tool, this lite up brake, abs light on dash. Could this be causing the engine to lost acceleration somes or what bcos the engine some time lost acceleration when try to kick down and there is no fault code pointing to throttle.
forumoto
Has thanked: 1 time
Post by forumoto »
