This car is going to be the death of me. 94 855 timing belt
- Has thanked: 1504 times
- Been thanked: 3817 times
Re: This car is going to be the death of me. 94 855 timing b
Okay then the Swedish dragon has sustained a mortal wound....
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
LOL, always something.
Next time your timing is a tooth or so off, and you have NOT released the tensioner pin, you can turn the cams with the belt on. There is enough slack in the belt loop for the cam sprockets to turn back or forth, jump the belt to get dead on.
When doing heads, there is no reason to pull the cam sprockets. If you do pull the cam sprockets, check the back of the cams before securing the sprockets with the cover installed.
- 332 Views
Last post by GreenMagicMan
- 4242 Views
Last post by jimmy57
