2000 v70xc car died and now won't start
mrscullini
- Year and Model: 05 XC70, 08 XC70
- Has thanked: 1 time
possible...not probable. test executed the same way as always.Atis wrote:Sorry for the question, but could it be that the compression test was not executed correctly?
plus...the starter motor spins as though the bendix is not engaging on the flywheel. tells me that there is no resistance due to compression building on that stroke.
mrscullini
so this suggests a major failure...with all plugs installed, i can turn the motor without any resistance.
as i think back, the motor began to gradually loose power. as i was on the highway, speed would drop. i would drop down a gear to get back up to 65. this happened multiple times. finally, i was revving out at ~4k to maintain 50 and then it died.
mrscullini
pulled the head...mystery solved. exhaust valves crashed into the pistons. pictures posted later.
- 922 Views
Last post by misha
- 110 Replies
- 17361 Views
Last post by bmdubya1198
- 2709 Views
Last post by mf70
- 15428 Views
Last post by Sea30
- 875 Views
Last post by Dashiel
