Did you find that the long suction line was loose? Should it be attached to something? I am looking inside my drivers side port and see that mine is not attached to anything. I also posted this question elsewhere in this post, but saw your note so thought to ask you specifically.
Thanks much!
**Updategoldxc70 wrote: 14 Apr 2017, 23:42 My problem is my 2004 acts like it's running out of fuel when the gauge shows about 1/8 full. My guess is that the long suction line to the driver side has either come loose or is damaged or blocked. However, I have ordered a replacement pump just in case. Either way, I'm going to follow your excellent directions to check it out and will report back afterwards. Thanks in advance!
UPDATE: I followed this write up in preparation for my new fuel pump to arrive. It's very good and makes things almost obvious when you're actually doing the job. When I ordered my pump, I neglected to order the tool so decided to make one myself while waiting for the pump. I used a piece of left over 4" ABS pipe and cut 18 slots into it using a table saw. Then, I put a few holes into it so I can insert a lever. Here's a pic.
In doing the project, I found that Yes! -- the white suction pickup is supposed to be connected to the bottom of the drivers side cover/level sensor.
