98 v70 non turbo burning and or leaking oil
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Put some cardboard under the engine overnight after a drive. Should show you if you have a drip and, if so, where it's coming off the block. You can follow the trail up from there to the source.
98v70dad
Year and Model: 98 V70
Has thanked: 1 time
Post by 98v70dad »
I've been monitoring the oil use and keeping a record. Last oil change I put in valvoline 10w30 for older cars thinking if I had some leaking seals it might help with that. So today I checked the oil level. It is exactly one quart low after just under 2000 highway miles. I don't think I have any leaking seals since the older car oil didn't help. That seems pretty high to me since the car has only 130000 miles on it. Should I be concerned or just go to a heavier oil like 10w40. I get a big puff of blue smoke when I start the car in the morning. No blue smoke when I'm driving it. Probably valve seals. I've had other cars do this but not as much consumption as the volvo.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Switch to heavier viscosity oil.Yes you have bad valve stem seals since you have a puff of blue smoke at start-up and after prolonged idling.
10w-40 will low your oil consumption.
Add some oil in it,do not drive the car with oil level under the middle of the dipstick.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I agree with misha. This is almost surely leaky valve stem seals, and 10w-40 will help but of course not cure it.
j-dawg
Post by j-dawg »
A quart every 2,000 isn't really that bad.
Not factory fresh, but certainly nothing to panic about. Keep an eye on it and don't let the level drop too far.
I've been adding a quart every 750 or so for the last 25,000 miles and it's been fine. Planning to take care of it soon....but I've been doing that for the last 25,000 miles too, so y'know.
Has thanked: 1610 times
Been thanked: 4065 times
One quart every 2000 miles means check your oil once a month, and carry a spare quart with you at all times. My 1999 has burned at this rate since 30,000 miles....maybe a bit more later in life, but It went back down with a change to synthetic at 150000 miles.
98v70dad
Has thanked: 1 time
Post by 98v70dad »
j-dawg wrote:A quart every 2,000 isn't really that bad.
I'm not that concerned about it, but I've never owned a car that used this much oil with only 130,000 miles on it.
These threads can quickly go off rail but:
from GM documentation...
Oil Consumption
The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi).Models:
1998-2009 GM Passenger Cars and Gasoline Powered Light Duty Trucks Under 8500 LB GVW (Including Saturn)
How the first owner treated it probably determines if you the usage.
in our house we experience:
One Volvo - 1 liter/2000 miles
Other Volvo - none
VW, VW - none
BMW - 1 liter per 5000 miles
