No, I have not. Forgot to do so. Where is this built in diagnostic tool located?misha wrote:It's because ecu is programmed to totally ignore data from o2 sensors on hard accelerating(full throttle) and to use default values.The reason is that car always have it's maximum power when it needed and there is no risk that ecu will cut off fuel because o2 sensor reads too rich at the moment.
Btw...did you reset codes after o2 sensor replacement?'95 have built in diagnostic tool under the hood.
1995 850 GLT O2 Sensor closed loop fault
JDS60R
- Been thanked: 3 times
Your maxed out on fuel trim . The car is adding 25% more gas than needed (it thinks its hyper lean). You need to find where the extra (unmetered) air or faulty sensor data is coming from . The oxy as shown is working on a normal pattern but you are running full rich 25%+ltft as it thinks its full lean. You have to figure out why it thinks its full lean and why the oxy sensor isn't reflecting it.
Time to look at the sensors that control A/F ratio - O2 (both) , MAF, ECT (coolant)
as well as major air leaks or dirty injectors or low fuel pressure .
That oxy sensor is a regular pattern but should be pegged at .1 volt if the engine was really running that lean.
Lets map out both oxys, the maf, coolant temp sensor and trims. So you can see the whole picture.
Raise rpm to see what happens . If its a small air leak the trim should get better with higher 3K rpm.
Retired
JDS60R
If it ran correct before the o2 change - get rid of that O2 sensor. Make sure to change both with direct fit Bosch ( if OE was bosch)
That open loop period could also be an open circuit as an O2 (zirconia) sensor makes its own voltage.
Retired
- misha
- Has thanked: 155 times
- Been thanked: 432 times
http://volvospeed.com/volvo_repairs_how ... es_a2.htmlmoacyr wrote:No, I have not. Forgot to do so. Where is this built in diagnostic tool located?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
I would say that your o2 sensor is dead.It is o2 sensor or the wiring.It doesn't produce voltage at all and there are no readings from it.
According to all this data,the car must be running super rich(black smoke from the exhaust and abnormal fuel consumption.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
JDS60R
Minimal change at higher rpm. Look for sensor issues instead of mechanical.
ECT of 90c (194f) is ok but a touch low - not worried about it.
Where are both oxy readings ???
Retired
- 1779 Views
- 1582 Views
Last post by Steve in Beacon
- 999 Views
Last post by nico416
- 930 Views
- 2490 Views
Last post by TripleThreat719
