By now it probably has 185, 300 miles.
2001 xc70. ETM & PCV
precopster
- Year and Model: Lots
- Been thanked: 128 times
Arthur is there something wrong with your computer?
Arthur2001xc70
- Year and Model: xc70 2001
Sorry. I just switched from an iphone to a blackberry. I'm still getting used to the new interface.
Arthur2001xc70
If I were to swap in updated connectors wouldn't I need to have the unit's software updated at a dealership? I'm a 9 hour drive from the nearest. That's why I thought the (super expensive) Xemodex - pre-programmed one was my only choice.
precopster
No need to reprogram your own unit. Swap it in and forget about it. Research this and other forums.......
Arthur2001xc70
I've done a bunch of reading and have come to the conclusion that I should buy the pre programmed module from Xemodex. I'm much more comfortable with wrenches and tubes than circuits and volts.
precopster
Xemodex units have a proven track record.
They seem to have overcome the inherent issues of an uncooled circuit board directly attached to a lump of hot metal
Arthur2001xc70
Thanks for the comment. And apparently they are on sale this month. So next pay cheque I'm going to order one and stay within my skill set.
Arthur2001xc70
This also might seem like a naive question, but in reading the tutorial on how to replace the Pcv system it is advised to remove the fuel pump, crank the engine over and then replace the fuse. But couldn't I just pull the fuse from the fuel pump and bleed the line from the manifold?
Arthur2001xc70
Excellent!!! That will make a difficult enough job a little easier.
- 4508 Views
Last post by ajwsurfer
- 4962 Views
Last post by antonevane
- 15 Replies
- 6767 Views
- 4720 Views
Last post by firstv70volvo
- 627 Views
Last post by rcherry506
