Thanks
Is there a way to get the harness woring drawing? That same harness worked for 3 months with another coil
2001 S60 T5 burning coil issue
- Has thanked: 1611 times
- Been thanked: 4074 times
We don't host wiring diagrams here by agreement with Volvo but you are allowed to post them from the web. Find your exact model and year and look for engine management section
OK, thanks
BTW, i did see on the pictures that both your pictures and mine shows the same #1,2 and #4 wires hooked to the connector but the polarity may be different
Shall look on the web for the wiring diagram
I don't have a clipped wire, so that's still a mystery. I think the fourth connector grounds through the body of the coil, so if that wire isn't grounded that will give big problems. Open grounds on power circuits are bad. Polarity on power transistors is really important.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Was the short in the loom leading to the coil packs or was it elsewhere? That info might help the next victim of this problem.
