2001 S60 T5 burning coil issue
rmargoli
Year and Model: 2001 S60 T5
Post by rmargoli »
Helppppp
I own a 2001 S60 T5 for a few years now and with no significant issues untill about 6 months ago
During last winter i accidently entered a small puddle and about 15 minute later the mottor started leaping. My mechanic told me that there are issues with Coil #1, he replaced the coil but the issues continued and the coil kept on burning. At the begining it took a few days for it to burn but later it was happening fast.
Next thing he did was to replaced the main harness that is hooked to the coils. after that, the car worked for 2-3 months (minor leaping) but after about 3 months coil #1 (same coild as in the beggining) was burning again.
At that time he said i had to take the car to the volvo service center for them to hook it to a VIDA computer which i did and the service center told me that the comuter was not OK. I sent the comuter to a local fix shop and they told me that nothing is wrong with it (all singnals are properly working) and in any case, there is nothing in the comuter behaviour that would couse the coil to be burned. I did understand that but in any case i bought another use ECM unit, gave it to the computer shop for it to be programed and instaled it in the car
And... coil #1 is burning again !!!
Did anyone encounter such an issue?
Where can i look for the problem?
Is there anything that can couse a short circuit and the same coil to be burned? anything beyond the harness?
Thanks in advance
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
From your post I am going to presume that the high voltage side is failing. That indicates excessive load which leads to the condition of spark plug. The ceramic insulator needs to be clean, also gap should be proper (unrelated however to the water puddle event). Then I'd check the corresponding ground for that coil to make sure the aluminum landing surface is clean.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
As above. Somebody's missing something here. Is the coilpack actually being verified as burned or does that cylinder simply fail to fire?? This could be wiring issue if misdiagnosed where a short takes place limiting output to coilpack #1 and garage is assuming it's burned without taking measurement at coilpack connector.
The coil wiring on top of the motor has common ground for at least 3 cylinders. The spark plug further along the chain can cause burnouts of the coil.
You didn't mention if you are using 9125601 genuine coils or the equivalent OEM Bosch units. Aftermarket coil packs can last a very small amount of time and are correspondingly cheap. Recently I picked up a Valeo coil which wasn't cheap as nothing else was available close by. No name coils to be avoided due to poor materials used.
rmargoli
Post by rmargoli »
Thanks for the response
The coil my mechanic has been using was always a genuine volvo coil (took a picture and it shows 912xxxx). The coil is actually being burned and even melting so is becoming a failed coiled no dought about that
As i mentioned below, the harness that hooks the coils to somewhere (which i do not know where as i do not have the car's drawings) has been replaced and it took 2-3 months until the phenomena occured again
Ron
Has thanked: 1609 times
Been thanked: 4063 times
If the coil melts it has to be either electrical or mechanical
Check the current draw and resistance on the coil. I can think of how a wiring fault in a loom would melt a coil without a fault so I doubt that's it.
I would suspect a bad spark plug thread letting blow by up into the coil, melting it by heat transfer. Pull the plug and see if there are any marks of gasses on it to check.
rmargoli
Post by rmargoli »
also, all 5 spark plugs had been replaced 3 months ago
It could be the thread in the cylinder head is stripped or even a bad new plug with a crack. Usually you would notice rough running or a code but it's possible to miss it on a 5 cylinder car
rmargoli
Post by rmargoli »
I think that the coil was miss behaving even before the plugs where replaced. Could it really be that the cylinder itself could be the issue?
precopster
Can you post a pic of one of the burned coils? Is the heat from the bottom end burning through the rubber insulator and going up to the wide area of the coil? Or is the heat/melting at the head where the part number is written?
rmargoli
Post by rmargoli »
will open and see
