Ah, I understand now.
What other tests can I do to diagnose these failed parts?
1995 850 Intermittent misfire at idle / accel.
- jnitschke123
- Year and Model: 2006 V50 T5 AWD
Current:
2006 V50 T5 AWD 6 speed - 240k Kilometers
Gone:
1995 850 GLE Wagon, 10 valve - 190k kilometers
1997 850 T-5 Wagon, ex-US car - 225k miles
1998 V70 SE Wagon - 300k kilometers
Gone:
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Ats sensor resistance can be measured with digital multimeter.Procedure is almost the same like measuring ect(coolant temperature sensor) except it is not dependable on engine temperature,but is dependable on ambient temperature.
Find specs for resistance depending on ambient temperature and measure it.Also...there are plenty videos on youtube for how to check map sensor.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Something to begin with:
Map sensor testing
Instead of vacuum pump,you can create a vacuum with your mouth.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
Thanks misha!misha wrote:It's not a Maf....it's Air Temperature Sensor(air thermistor).
10 valve cars have totally different sensors because they have different engine managements than 20v cars.
This car doesn't have Maf...it have MAP sensor instead of Maf. ...
Now that you have cleared the codes, see which one(s) come back. If that TPS code comes back that is mighty suspicious ... O2 and MAF codes can be thrown by many things notably various vacuum leaks. A TPS code pretty much always traces back to the sensor itself.
I am no help at all on the MAP/MAF/thermistor questions.
joelobstahman
- Year and Model: 1997 850
jnitsckke Did you ever find out what the cause of the skipping was? I have a 1997 850 that is doing the same thing and it is mind boggling.
Thanks
Thanks
- 11 Replies
- 2236 Views
Last post by Sommerfeldt
- 1103 Views
Last post by erikv11
- 1390 Views
Last post by alexk243
- 638 Views
Last post by Cal01s80
- 2168 Views
Last post by Craigd2599
