98 s70 GLT Misfire
samtron6
Year and Model: 1994 850 non turbo
Post by samtron6 »
got old wires on but old plugs were burnt from old owner not changing them..... put i did use another set and still same thing... just dont make since just changed wires and plugs and all this crap happens
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Old plugs were burnt and you got misfire right AFTER you changed them?!Before replacement everything was fine?!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
samtron6
Post by samtron6 »
yes sir everything was absolutely fine before... idk whats going on
charleskennedy23
Year and Model: 1998 V70 T5
Post by charleskennedy23 »
I'd take the plugs and wires back and get you a set of bougicord wires and OEM plugs. FCP sells the kit and it will come with a lifetime warranty...
Charles Kennedy
"HAGRID": Black '98 Volvo V70 T5
samtron6
Post by samtron6 »
other plugs and wires are back at autozone but needed to get to work so bought the autolite copper 3923 plugs and used old bougicord wires
misha
Post by misha »
Is misfiring gone with old wires?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Misha, here is your answer from page one:
samtron6 wrote:well old wire are in and everything was fine till CEL on again..... now its random misfire,,,,, and misfire cylinder 2 and 4 instead of 2/4/5... plugs are gapped right wires are in the right spots... after CEL comes on it runs like crap for a few then runs fine till i sit at a long light then it tries to bogg down for a second when giving gas... never did this till i changed plugs ??????
Test the MAF, it's free (unplug it before starting the car, drive around).
misha
Post by misha »
I missed that post erikv11. :wink:
Bad Maf will not cause misfiring,you know that.
Check cap & rotor.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
samtron6
Post by samtron6 »
how would i check the cap and rotor lol sorry just got off working after working 19 hours
misha
Post by misha »
Remove it and visually check contacts inside of it for burnt traces or corossion.Or take a picture of contacts and post them here.
19hours....i would get myself a good sleep before doing anything.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
