There's an ejector pump that brings the fuel from the saddle to the main pump, so you should have gotten most of it out your way. How long did it take, I'm curious..DPDISXR4Ti wrote:Only one? I've had a few. Most recent project turned one into a Ute. Search "Project XRBrati" for pics if you're interested.JRL wrote:Changing the subject. You either have or had an XR4Ti Merkur?
Back on topic...
Cut the fuel line at the fuel rail, attached a hose to a gas tank. Found the fuel pump access panel under the rear seat (driver side) and snipped the blue and black wires. Using a 14.2 volt Ryobi battery, I powered the pump directly and out came the fuel. I think I've got about 12 gallons out so far, before it started sputtering.
The owner indicates that he had just filled it up before it died, so it seems there should be more fuel in it. So I'm wondering if there's any magic that needs to happen to get the fuel over from the other side of the saddle tank. Is there some sort of cross-over tube?
2001 XC70 - Pumping out fuel tank
- Been thanked: 4069 times
- 646 Views
Last post by volvolugnut
- 5158 Views
Last post by vajdaviktor
- 2820 Views
Last post by BigSpud
- 38 Replies
- 9242 Views
Last post by jking4020
- 5599 Views
Last post by loosenut
