Symptoms of a dying head gasket?
Has thanked: 1610 times
Been thanked: 4065 times
wrybread wrote: 26 Nov 2020, 08:23 It's still running fine. Can anyone comment on what I can expect? How long will the car be usable? It's probably heading to the great junkyard in the sky when it's done, as opposed to the mechanic shop.
I’ve run the simulation on my Cray and the engine will catastrophically fail August 29, 2029
Enjoy it until then. I don’t like “ head gasket in a can” and recommend its non-use.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Ha, I ran the same simulation on my TRS-80. Aug 28, 2029.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Hold for a tie breaker check. My wife is checking on her abacus.
:lol:
volvolugnuty
wrybread
Year and Model: 1998 S70 GLT
Has thanked: 15 times
Been thanked: 15 times
Post by wrybread »
So far so good: I add water every morning that I'm using it, and it usually takes about 1/4 of a gallon. The temperature gauge stays pegged at 3:00 the whole time I drive it. However, when first starting, it runs a little rough for a moment, like one of the cylendars isn't firing. Then it'll start firing, especially if I give it a little gas, and all will be reasonably well in the world.
I've been meaning to investigate this one though: when I give it that initial gas I can hear a little water rushing around sometimes. I know that's a ridiculously vague description, but any idea what that might be off the cuff?
Carlo the Nautic Blue 1998 S70 GLT
Previously Diego the 2000 S70, now has a blown head gasket and is awaiting the coroner
wrybread
Post by wrybread »
Ol Diego is still hauling boards and boats to the beach though.
It is a water jacket to cylinder leak. As long as it stays out of the oil you can run that a long time. For us In antifreeze country that 1 liter per day would bankrupt us but you can keep adding water to keep it moving.
If you look in the cylinders with a bore scope one of them, or more, will be squeaky clean - like it’s been steam cleaned. That’s because, well, it’s getting steam cleaned.
