My relay has 87-1 and 87-2 , did 30 to 87-2 that's the one that got very hot, by 30 to 87a you mean 87-1 on mine correct? thanks.lummert wrote:I forgot to mention that I used heavy gauge wire and a 30 amp fuse for the jumper. try connecting the jumper from 30 to 87a which goes to the pumps. Then try 30 to 87b which goes to the rsr. Does the wire overheat in both tests.
1990 740 gle gas delivery problem?
Ok, did 30 to 87-1, no fuel pump sound, went back to 30 to 87-2, started with quickstart for about 2 seconds then died, jumper wire got hot again and smoked before I grabbed it off, used a sturdy paper clip, I'm thinking that points to the fp relay or the power stage maybe???
Was I suppose to get the fuel pump sound when I went 30 to 87-1, there was no fp sound, thanks.joedrt77 wrote:My relay has 87-1 and 87-2 , did 30 to 87-2 that's the one that got very hot, by 30 to 87a you mean 87-1 on mine correct? thanks.lummert wrote:I forgot to mention that I used heavy gauge wire and a 30 amp fuse for the jumper. try connecting the jumper from 30 to 87a which goes to the pumps. Then try 30 to 87b which goes to the rsr. Does the wire overheat in both tests.
There's a grey wire that goes from the f injectors to the fuel control unit pin 18, any way to test pin 18 with multimeter? and a green n red wire to rsr relay #3 pin, any way to test that one?, thanks for direction, hope I'm getting close.
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Which engine is in your 740 GLE? And yes, the terminals are 87/1 and 87/2.
The gray wire that connects to LH ECU pin 18 is what switches (pulses?) the ground to the injectors.
wiring diagrams:
http://www.volvowiringdiagrams.com
wiring diagrams:
1988 Volvo 760 Turbo Wagon
B234F, how do I test ecu pin 18? the procedure I mean, with either a test light or a multimeter, have both and can I test green n red wire to rsr relay #3 pin, just tried a new fuel injection relay, the 1 in the fuse box, same condition, thanks.lummert wrote:Which engine is in your 740 GLE? And yes, the terminals are 87/1 and 87/2.
wiring diagrams:
- 29 Replies
- 4990 Views
Last post by 93Regina
- 2177 Views
Last post by lolafiona73
- 11 Replies
- 2024 Views
- 388 Views
Last post by cn90
- 1107 Views
