1990 740 gle gas delivery problem?
Hi, just got this 1990 740, previous owner replaced in tank fuel pump with kemso 340 high with 43 psi and eliminated the external fuel pump, it's kind of hard to start, seems under powered and sluggish, getting codes 232 and 221 from under hood diagnostic box, wondering if I need to put the external fuel pump back on to make it run right or if it's something else. Any ideas greatly appreciated, much thanks.
I'll need to get a fuel pressure tester from parts store, I'll try to do the heat test on the O2 sensor, kind of strange, it will idle good for about 4 or 5 minutes, then just dies abruptly, just like turning the ignition off, on the tests with the on-board diagnostics, it failed the fuel injector report test, thanks for reply.93Regina wrote:If fuel rail pressure is good to go at start-up, then look elsewhere....like O2 sensor, leaking injector, etc.joedrt77 wrote:1990 740...
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
With older vehicles, I put $$$ into them so these issues don't appear. Like I replace,joedrt77 wrote:...kind of strange, it will idle good for about 4 or 5 minutes, then just dies abruptly....
FPR
CPS
Fuel Relay
Ignition Control Unit
Drive-shaft carrier bearing, and check U-Joints
Front end parts, where needed, hub bearing, or repack wheel bearings
New Bougicord ignition wires, cap, rotor, and sparks; and sometimes coil
If those two codes exist, it could be CPS, relay, O2 sensor, AMM...etc...etc
One has to start somewhere...doing a rail pressure check can determine if fuel circuit relay is shooting craps.
A trouble code may or may not point to the defective part or relay, etc. A failing AMM could be your issue...but one needs to nail down the issue.
Now at a no start without a shot of starting fluid, have a cps on the way, still no fuel injector report with on-board diagnostic test, no test port on fuel rail for fuel pressure test, fuel pump is engaging, fuel pump relay is clicking every time I turn the key on as expected, tried to pull fp relay out, wouldn't budge, thinking fuel injectors are not firing.
- 93Regina
I would suspect any 4 cylinder vehicle with an EFI system would be the quick/dirty solution.joedrt77 wrote:...faulty coil..
>not getting 12 v at fuel injector connector
Radio Suppression Relay bad! Car won't Start!
- 29 Replies
- 4973 Views
Last post by 93Regina
- 2176 Views
Last post by lolafiona73
- 11 Replies
- 2021 Views
- 383 Views
Last post by cn90
- 1101 Views
