On Range Rovers and BMW it is a very common issue. Exhaust manifold, cracked cat, and loose spark plug are always recommended places to start. Take a hose to ear and move around the areas.
For proper repair look at this link regarding fasteners. viewtopic.php?f=9&t=86178
One question on your car - Volvo switched to solid lifters at one point. My 2001 engine had solid lifters and a single VVT. Can anyone in the "know" provide a more precise cut off date? Would be helpful for future searches.
lifter noise?
- SuperHerman
- Been thanked: 207 times
- RickHaleParker
- Been thanked: 979 times
Aphx: Did you try using a transmission funnel as a ear trumpet to isolate the sound? You can smoke test an exhaust system just as one does with the evap system, just blow smoke up its waste pipe and see where it comes out.
Active
Past
Past
- Has thanked: 316 times
- Been thanked: 531 times
VVT started on 1999 MY turbos and 2000 MY NAs. Solid lifters began with 2000 MY NA (not sure if this was a mid-year update or it was for all 2000 models) and likely the same for turbo models.SuperHerman wrote: 05 Aug 2018, 12:09 On Range Rovers and BMW it is a very common issue. Exhaust manifold, cracked cat, and loose spark plug are always recommended places to start. Take a hose to ear and move around the areas.
The easy way to tell if the car has solid lifters is to remove the spark plug cover and look for several torx head screws positioned on the front and rear edges of the cam cover. There will be 20 of them, one for each valve.
If you search around on Volvospeed, there might be some info on VVT/solid lifter cutoff dates or engine models.
That sounds nasty. At first it sounds like an exhaust leak, but when you rev it up a little bit it sounds like it could be lifters. What kind of oil are you using? I have found heavier oils (10w30) make the lifters a little noisier. I doubt that's a problem if it just started happening, though.Aphx02 wrote: 05 Aug 2018, 11:52 Yup, mine has the same symptoms and this will be the first area to check. I've been reading the past 4 hours on what it can possibly be and your post may have my solution....here's my clip
- 21 Replies
- 3340 Views
Last post by rspi
- 3924 Views
Last post by Klausc
- 1701 Views
Last post by Boosted40
- 1350 Views
Last post by JIMMYCNOTES
- 1665 Views
Last post by Redbox
