volvo850diag has a ECU 51 (ie, COMBI Instrument Panel) "Test Gauges" function which (among other things) wll cause the Temp Gauge needle to swing thru much of its range of motion. If you do that "Test Gauges" check, please tell us exactly how far down the needle swings in relation to the red mark at the bottom of the Temp gauge and how far up the needle swings in relation to the red zone at the top of the Temp gauge.
I'd suggest doing it several times to see if the behavior is always consistent.
Cooling Fan Coming on Late, I Think? Topic is solved
esl_97_850_T5
- Has thanked: 18 times
- Been thanked: 27 times
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Hmmm, Not sure what is going on there. Maybe a bad gauge, I have had to replace one of them.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Just experienced this and made a new post about it. I didn't even know the fan HAD two speeds. So the low speed connector must have come off as my fan speed suddenly jumped up. When I touched the relay, it would quickly rise/fall/rise/fall....jimmy57 wrote: 21 Jun 2017, 07:10 If the low speed connector comes off its pin on fan relay then the high speed fan will be triggered at a higher temp. The plastic on those "bullet" style connectors disintegrates and the grey plastic connector body can't keep them on. Easy to inspect. Look just under that top fan shroud plastic bar for the big rectangular relay and see if the grey plastic two wire connector has a loose wire. If it is loose then push it back up on the pin on relay.
Obviously I have another 'bullet' connector/housing/contact to fix like the ECT I did last year.
M1 10W-30 HM
M1 10W-30 HM
- 1461 Views
Last post by chrism
- 975 Views
Last post by Pilot9302
- 12 Replies
- 2294 Views
Last post by subzerocarfanatic
- 13 Replies
- 4223 Views
Last post by gswede
- 1768 Views
