Shiftlock Release is stuck - Help
- Has thanked: 17 times
- Been thanked: 35 times
Did you try turning the steering wheel as you pull the key?
oh i replaced the gear shifter 6 months ago... bought some fancy looking on ebay and had to do bunch of modifications but it works now. after doing so, i ve seen someone selling really good looking shifter w wooden knob but already got mine replaced.
S70 1998 Automatic
Well, I finally got around to taking the consule apart as posted earler on my V70 with 91,000 miles. I pulled the gear shift knob off and looked around in the area. I found a cable near the bottom of the gear shift on the pasenger side that when I pulled on it, clicking was heard around the key. It seems that the cable was stuck and moving it released it to move that allowed me to take the key out of the ignition switch. Problem solved.
Thanks for all the help.
VolvoMonkey
- Year and Model: V70 XC 1999
I know this is old, but just wanted to say that simply spraying some silicon lubricant on the shift release button did the trick for me!
- Has thanked: 311 times
- Been thanked: 817 times
I'm going to try this silicon trick, why not ...
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Remember - The shiftlock overide is connected to the same cable that runs up to the ignition lock.
Either button, the one on the shift lever handle or the overide on the console can lock up your key.
These cars are getting old, so it may also be a stretched cable. The adjuster is in the shifter end.
