Narrow Down Low Cabin Heat Issue Topic is solved
Has thanked: 1610 times
Been thanked: 4065 times
3. Someone mentioned making a platform to make it easier to work under the dash. I put a board on top of 2 five-gallon buckets, and a pad on top of that, and it made it a lot easier than when half of me is hanging out of the car into space.
This is an awesome tip for under dash work of significant time
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Someone left a comment on the heater core video, he said a trick so he didn't had to bent the metal tubes
- at the rubber heater hoses inside the engine bay, remove the quick disconnect and the mounting plate
- blow into a hole (use a small hose): this will empty a little the heater core so it won't leak when removed
- from inside the car, cut the tie wrap that binds both tubes at the top: once disconnected from the heater core, the metal tubes will move away easily - no longer needed to bend them to get them out of the way
