ATF for power steering fluid
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Do it just like the trans, remove the return hose at the reservoir, pump into a container, replace as you go, maybe a half-liter at a time. two to three cycles should have clean fluid in the whole system
Current Volvos:
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Ouch....that stuff needs to be flushed out.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 4064 times
Im concerned the Reds are contaminating our Precious Volvo Fluids.
- Danonly55
- Year and Model: 1996 850 sedan
- Has thanked: 23 times
- Been thanked: 4 times
Ok thanks guys, 1 last question, which hose is the return ?
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
" John Wayne
Isn't there only one hose on a pre-1999 - I thought the reservoir fed the PS pump directly??
- Danonly55
The fluid some how has to get back to the reservoir, I watched a vid on the pump change and there was 2 lines.
" John Wayne
" John Wayne
The big heavy line will be the high pressure line down to the rack. The one that looks like regular hose will be the return line. The fittings on the pressure line are swaged with a metal fitting, the low pressure line just a clamp (either a hose clamp, a Jubilee clamp, or one made by Oetiker of the Oettinger Clampett Family (for erik)
- 13 Replies
- 7697 Views
Last post by GlennG2759
- 4417 Views
Last post by amblerman
- 380 Views
Last post by subzerocarfanatic
- 11 Replies
- 11685 Views
Last post by STSCowboy
- 30 Replies
- 26974 Views
