Safe to Charge Battery Indoors?
Hydrogen dissipates really quickly by dashing off into atmosphere and then heading out to space where it becomes stars, it will blow up, but the only thing left in the universe by then will be random P0455 codes floating in space
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Seriously though. A battery that had been properly flat won't ever be reliable again as a starter so just get a new one straight away.
And check the car to figure out why it went flat. Unless you just had the car sitting for a few months in which case it's quite normal for it to be drained
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
Yep I’ve charged a different battery years ago and it did take a few years
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
- RickHaleParker
- Been thanked: 978 times
I have brought starter batteries back from deep dead. It does take more time then most people can be without a battery.Rattnalle wrote: 11 Aug 2018, 01:22 Seriously though. A battery that had been properly flat won't ever be reliable again as a starter so just get a new one straight away.
Active
Past
Past
- Rattnalle
They will never be anywhere near as good as new. They aren't designed to discharge more than a few percent. So it's a question of how much you value reliability vs cost.RickHaleParker wrote: 11 Aug 2018, 01:50I have brought starter batteries back from deep dead. It does take more time then most people can be without a battery.Rattnalle wrote: 11 Aug 2018, 01:22 Seriously though. A battery that had been properly flat won't ever be reliable again as a starter so just get a new one straight away.
- RickHaleParker
As long as the recovered battery is starting the car reliability, is as good as new. One of my recovered batteries is in my S90. It is reliable.Rattnalle wrote: 11 Aug 2018, 02:46 They will never be anywhere near as good as new. They aren't designed to discharge more than a few percent. So it's a question of how much you value reliability vs cost.
Active
Past
Past
- Rattnalle
Good that it works for you. I still wouldn't risk it and I wouldn't recommend anyone else to do so. The batteries take damage from deep discharge. If that turns out to be an issue depends on what it's used for I guess. I'm not risking standing in the middle of the forest in winter with a flat battery.RickHaleParker wrote: 11 Aug 2018, 16:13As long as the recovered battery is starting the car reliability, is as good as new. One of my recovered batteries is in my S90. It is reliable.Rattnalle wrote: 11 Aug 2018, 02:46 They will never be anywhere near as good as new. They aren't designed to discharge more than a few percent. So it's a question of how much you value reliability vs cost.
viper69
I'm done with figuring it out, trying to see if it will work or not. Time is too precious. I called AAA they replaced it for free.
Thank you all for your input however.
Volvo 850 GLT 1995
- 9385 Views
Last post by Rattnalle
- 3897 Views
Last post by 240bri
- 4393 Views
Last post by jgibbs2273
- 807 Views
Last post by axisdj
- 1089 Views
Last post by cloaked45
