I sure don't remember doing this when I did my radiator and thermostat , now I have another thing to keep me up at night.
Thermostat Replacement Advice
- Has thanked: 1500 times
- Been thanked: 3812 times
Re: Thermostat Replacement Advice
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
Before you get into it, are you getting any errors from the ECC module? (Are the lights flashing on start-up?)
You might have a bad damper door motor.
You also didn't mention whether the temp gauge drops when the car is moving.
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 52 times
I have the old fashioned manual climate control, so no ecc. It's a base model.
Temp gauge doesn't go down. I've already replaced the entire cooling system with the exception of the thermostat. So that was all that was remaining on the list.
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
- Chuck W
OK, still. If the gauge is staying "warm" while moving, that should mean the coolant is warm enough to heat, even when moving.
Whenever I've had the issue with lack of heat while moving that is thermostat-related, the engine temp also goes down.
It almost sounds like a recirc or ventilation door is not closed.
- Has thanked: 292 times
- Been thanked: 765 times
Unhook the reservoir and move it into the engine bay so it is below the level of the stat housing cover, pop off the cover and check the orientation. I've done this, you may spill a little bit of coolant but not much.
The needle on the gauge barely (or doesn't) moves at all through a wide range of temperatures, it is not very sensitive. So the engine temp may indeed be down - live data would clear that up. Anyway, OP has changed everything but the stat, probably worth finishing the overhaul regardless.Chuck W wrote: ↑20 Nov 2018, 06:28 OK, still. If the gauge is staying "warm" while moving, that should mean the coolant is warm enough to heat, even when moving.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
The needle just has to be barely in the white for you to have heat when stopped. I bet the problem is the door is stuck for the heat, or the heater core failed. When driving on the highway in weather below freezing, your temp gauge would be well below the 3 o'clock if the thermostat is stuck open.
Knows enough to be dangerous
- callahanoffroad
Just to clarify.
I have heat.
I especially have heat when I idle the car in the parking lot at work after driving around.
When I start driving (the water pump starts rapidly circulating) the heat diminishes. It doesn't go away. It's just noticably less. I suspect my thermostat is either stuck open, or more likely opening too early
Either way, I still need to replace the thermostat as it's the last piece of the cooling system that is 1995 original.
Does anyone have a diagram for a non-ecc climate system? I did a cursory search online and only saw ecc diagrams.
I have heat.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Each time I've had to change the thermostat, the temp gauge both on my 95, the current 96 and the 98 S70 would go down while driving and back up to middle when standing or crawling in traffic.
WhatAmIDoing and Chuck W has a very valid point - if the needle stays smack in the middle, the problem is likely to be somewhere else.
I've always been lucky with the thermostat changes, I guess... a long T40 and a good smack on the handle always break those torx screws free in my experience - knock on wood, have never stripped one so far.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Chuck W
This what you're looking for?callahanoffroad wrote: ↑20 Nov 2018, 12:40
MCC Manual
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
This is how to quickly test most thermostats. On most engines (but not all of them) the thermostat fails in more or less the open position - which causes coolant to flow continuously through the radiator even with a cold engine. The wider is stuck open, the less the coolant temperature. On a stat that's stuck very open, the temp needle will drop when driving at speed such as on highway in winter time because then the radiator gets cooled more by the air flow.
