2001 V70XC - Random stall when coming to a stop... Topic is solved
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Working my way through solving the two Accelerator Pedal related DTCs. Four readouts of all ETM parameter before removing accelerator pedal this weekend.
Engine OFF, Key POS II:
Engine idling close to 1000 RPM:
Engine idling and settles near 700 RPM:
Few minutes later engine cuts off by itself:
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
When the ETM on my '01 V70 was dying, it threw a few accelerator pedal-related codes. After having the ETM rebuilt, the accelerator pedal codes went away, so I'm fairly certain nothing was wrong with the pedal or pedal sensor in my case. I think it was just one way the ETM tried to interpret the data it was seeing.
I also frequently saw the absolute throttle position at 20% when the car was in limp mode.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
Has thanked: 1609 times
Been thanked: 4063 times
That should be documented here , somewhere...
What is the throttle plate position for limp mode?
Jimmy might know this.
xHeart
Post by xHeart »
abscate wrote: 19 Feb 2019, 02:21 That should be documented here , somewhere...
Found this viewtopic.php?t=87043
Hmmm
Turbo limp throttle angle 20%
Non Turbo limp throttle angle 16%
Nominal numbers
xHeart
Post by xHeart »
abscate wrote: 19 Feb 2019, 11:10 Hmmm
Nominal numbers
Found this: https://xemodex.com/us/pdf/ETM%20Flow%2 ... -final.pdf
xHeart
Post by xHeart »
prwood wrote: 18 Feb 2019, 20:45 When the ETM on my '01 V70 was dying, it threw a few accelerator pedal-related codes. After having the ETM rebuilt, the accelerator pedal codes went away, so I'm fairly certain nothing was wrong with the pedal or pedal sensor in my case. I think it was just one way the ETM tried to interpret the data it was seeing.
IF Limp Home is a "SAFETY" feature THEN something is triggering ECM-9180: Accelerator Pedal Fault -- limiting power to gas pedal.
VIDA's ETM test procedure says something like "a 13º (%) angle difference requires replacing throttle module". I'll try ETM test tonight.
Is that difference between requested and actual?
This might Be the best diagnostic for detecting limp mode we have found yet
Xheart, can you add the ECM CODES and P codes to this thread? I can map the P codes if you have the ECM
xHeart
Post by xHeart »
abscate wrote: 20 Feb 2019, 05:15 Is that difference between requested and actual?
I will.
Someone like precopster is more familiar with "difference".
Mike Lucas aka precopster video [youtube][/youtube]
Its sounds like difference between the measured film sensors that is allowed?
Mike has a Kingfisher stuck in his throttle body.
Added ETM part number to thread for bookmarking the great video on ETM
Also referenced it in ETM Room
