Omg! What does the dark transmission fluid color mean?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
natural4reelz wrote: 02 Feb 2019, 11:41 I cleared the code 2days ago and it hasnt came back on
But.......
Its sluggish and im wondering if it will get better.
You don't get it.
ECM = Engine Control Module
TCM = Transmission Control Module
ECM-530D (P0700) is stored in the ECM when the TCM requests that the ECM light up the malfunction indicator lamp (MIL).
If you erase ECM-530D (P0700) it will come back unless the TCM sends another request.
Unless you have a scanner that can read and reset the TCM codes, the error codes that resulted in the original requests that caused the now erased ECM-530D (P0700) may still be in the TCM.
When a control module has an error code, it sometimes use a substitute value that keep you going but can result in degraded performance. This might be the source of your "sluggish" performance.
That is why I said you need a scanner that can read and erase codes stored in the TCM.
In short: ECM-530D (P0700) means that the ECM got a message from the TCM that there is a problem in the transmission. No details, you need to contact the TCM to find out what the complaint is.
Active
Past
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
This topic continued in new topic Should I Keep This 2002 S60?
Also -> Amazon link
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Pretty sure the transmission plug needs a 19 mm wrench. Oil is 18 and I am virtually certain oil and trans are different and trans is one size larger.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
