P80 850 rear bumper bracket bolts (982831, M10x130mm)
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
The long bolt part number is 982831, it is a M10x130mm
https://www.eeuroparts.com/Parts/61378/ ... mm-982831/
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
That's a decent price, though there is shipping. I think I paid close to twice that at local dealer, regretting immediately that I hadn't sourced from local hardware, etc. My local dealership charges retail for everything, crazy expensive.
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
THANKS GOUPIL. Also noticed nobody has mentioned the length of the SHORT screws.
4 each 988182 986504 Flange Screw
IDPA says volvo says M10x20 988182 the short ones
Might order the screws from McMaster Carr - any better sources for quality 'graded' bolts? And what grade should I get?
NEVER OPEN THE HOOD !!!
850forum
Does a standard 850 exhaust have a removable end tip? Mine doesn't, and in fact after the last exhaust job, I found my bumper slightly melted. Maybe they threw away the end pipe without removing the tip piece ???
anyway, I wonder, if doing the job myself, I could just cut off the pipe to access the vertical bolt & then install a tip piece long enough to clear the bumper. How far does a correct tailpipe extend beyond the bumper?
850forum
But I can't afford to break one & not have a replacement on hand. That would put our car out of commission for days.rguzz wrote: 29 Oct 2019, 02:57 Unless you lose them (or one) they can be reused. They aren't on tight and come off easily, clean and use again is fine. But, if you're ordering the long ones, may as well I suppose.
If it breaks it will be way up top of the bumper where the captive nut is. You can zip tie or even tape the bumper cover back in place while your part comes if you don’t drill out the rivers until AFTER you get the long bolts out850forum wrote: 29 Oct 2019, 03:03But I can't afford to break one & not have a replacement on hand. That would put our car out of commission for days.rguzz wrote: 29 Oct 2019, 02:57 Unless you lose them (or one) they can be reused. They aren't on tight and come off easily, clean and use again is fine. But, if you're ordering the long ones, may as well I suppose.
I would buy new ones if you have any rain in your climate. These long bolts just get the elements thrown at them , mine were less than half their birth diameter.
rguzz
I think he refers to the short ones fastening the cover on, the side ones? Can't quite remember now. They are in the trunk, avoiding the elements, the 10mm ones. Anyway, no matter, replace or not, just don't lose them if reusing, which is what I did.
- 19 Replies
- 6833 Views
- 842 Views
- 12 Replies
- 8738 Views
- 1440 Views
- 6269 Views
Last post by volvolugnut
