850 LPT wrote: 13 Mar 2019, 09:26I don't want to confuse things, but are you sure you can just unplug the downstream O2 sensor?WhatAmIDoing wrote: 13 Mar 2019, 09:06 Exhaust is your problem. If you have a cat efficiency code (I bet you do), unplug the downstream O2 sensor and the car will think the cat is fine, but you must disconnect the battery for 15 minutes to reset the ECU. Either get that exhaust buttoned up tight, or order a new one. Without seeing it, it's hard for me to say what would be better.
From what I understand, people install spacers for them when they delete cats to make them less sensitive. This would prevent the ECU from throwing the inefficiency code.
I agree though, the exhaust has to be tight. That would be the very first step to solve this.
Yes you can, been driving with the downstream O2 sensor unplugged for 30k miles. Runs great, no limp mode, get 2 codes relating to bank1sensor2 voltage and heater circuit malfunction. Gas mileage is normal. Goes into closed loop. LTFT doesn't do anything weird. If I plug the sensor in, car runs exactly the same until it throws a cat efficiency code, then it runs like crap. Disconnect the sensor, disconnect the battery to reset codes and fuel trim, she's happy again. Maybe on the turbo ECUs they are tuned differently regarding what input the downstream O2 provides, as having it unplugged is causing no problems other than a CEL for me?Sommerfeldt wrote: 13 Mar 2019, 14:05 Yeah, you can’t just unplug the O2. The Long term fuel trim will get all crazy, and do exactly what OPs problem describes. There’s been some theory running around for a long time that the rear O2 just checks the health of the cat, but it seems pretty clear that both of them influence the LTFT. A spacer could work, but fixing the exhaust and getting a cat in there would be the only real fix.
Or modify the programming.
One thing that is concerning, is the throttle lag. It kind of points to an air leak somewhere, when there’s not enough correction in fuel trims to account for it at some specific load point. OP; have you read error codes, and if so, what were they?
- S
