Serpentine Belt broke while driving - new belt won't install!
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Every Volvo Serp Belt I have done, releasing the tensioner wrench results in some travel. So it shouldn't be bottomed out.
If the belt is too short it will wear quicker and put added stress on your harmonic balancer, PS pump, A/C, and alternator. You don't want this as any of these will cost you dearly.
Shanestrait
Year and Model: 2002 S60
Has thanked: 1 time
Post by Shanestrait »
Copy that
In your guys' experience, has the belt taken much effort to get on? As it stands, it would require a Herculean effort.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Shanestrait wrote: 16 Mar 2019, 00:16 In your guys' experience, has the belt taken much effort to get on? As it stands, it would require a Herculean effort.
The key to answering that is now close is it to going on? Is the last bit of belt just coming up short a millimeter, a split hair or what?
Active
Past
Shanestrait
Has thanked: 1 time
The last attempt before it damaged the pulley, it was mostly on the pulley but we were unable to fully seat it. Two sets of hands trying to pry it on were unsuccessful.
RickHaleParker
Shanestrait wrote: 16 Mar 2019, 00:29 The last attempt before it damaged the pulley, it was mostly on the pulley but we were unable to fully seat it. Two sets of hands trying to pry it on were unsuccessful.
"mostly on the pulley" All the belt grooves in the pulley grooves or not?
The grooved pulleys have the highest resistance to belt slippage, another reason to try to slip the last part over the smooth tensioner wheel.
Active
Past
Shanestrait
Has thanked: 1 time
Not all grooves were on.
So you would recommend attaching to the tensioner pulley last? I'm also going to get myself a beefier torx setup so I can hold the tensioner back with more ease.
Shanestrait
Has thanked: 1 time
UPDATE
Went to O'Reilly's, bought their belt, SLIPPED RIGHT ON. Smooth as butter. Never using Autozone again.
Now the question is, is the chipped pulley a no go.
Has thanked: 1609 times
Been thanked: 4064 times
Lets see some pictures. Take a careful look at the plastic to make sure you can see ALL of the cracks, not just the big ones.
PS Pulley replacement is not for the faint of heart.
Shanestrait
Has thanked: 1 time
DO you have the piece that broke?
I would JB weld it back on from the outside, and run that puppy to Minsk like that.
IF you don't have it, remove belt, remove plastic burr from edge of broken pulley, run belt, and inspect belt for edge wear
First hour of operation
Daily for a week
Weekly for a month
Every oil check thereafter.
