Volvo to put cameras inside its cars to watch you next year
precopster
Year and Model: Lots
Been thanked: 128 times
Re: Volvo to put cameras inside its cars to watch you next year
Post by precopster »
One of the best innovations a company could incorporate is the 2 second gap warning system to let the car behind you know that for the given speed they are travelling (and the speed that you are travelling) that they are dangerously close and could collide with you in case of an emergency stop.
It could be implemented at speeds above 30mph. Each time I get into my car I have looneys driving behind way too close behind including heavy trucks and heavier laden vehicles such as work utilities.
This innovation is easily implemented, is non threatening as the car is telling them by means of a color coded warning system (such as purple) It would help to prevent people brake-checking each other and other dangerous ways of letting the driver behind you know such as the middle finger.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
precopster wrote: 24 Apr 2019, 01:29 One of the best innovations a company could incorporate is the 2 second gap warning system to let the car behind you know that for the given speed they are travelling (and the speed that you are travelling) that they are dangerously close and could collide with you in case of an emergency stop.
The U.S. trucking company U.S. Xpress has a system that slows down the truck and resets the following distance if it is too close.
Every time a four wheeler cuts off a U.S. Xpress truck, the truck slows down to reset the following distance.
Annoying to the US Xpress driver and anybody follow him.
U.S. Xpress has stated the investment payed off in a very short time period.
I like to see a system that scolds the passer if they try to change lanes too soon.
Tex69
Year and Model: 2007 V70 R
Has thanked: 5 times
Post by Tex69 »
93Regina wrote: 23 Apr 2019, 23:30
Tex69 wrote: 23 Apr 2019, 10:14Elderly drivers, and some ages in between can be equally dangerous.
Studies have show younger and older drivers are somewhat equal, with those between more safe. But causes are different for younger vs older.
Be that as it may, observing while out on the road, we can see evidence of those in that mid range driving badly. My own experience seems to indicate it's probably close to equal, with causes being different across the spectrum.
Past: 1993 940 turbo wagon
2007 XC70
Current: 2013 XC60
2007 V70 R
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Tex69 wrote: 24 Apr 2019, 16:54while out on the road, we can see evidence of those in that mid range driving badly.
UK: SUPPORTING SAFE DRIVING INTO OLD AGE: A National Older Driver Strategy
Police records show that the risk of an older driver over 70 killing a pedestrian is less than that of middle-age drivers and half that of drivers aged up to age 25.
93Regina
Post by 93Regina »
RickHaleParker wrote: 24 Apr 2019, 12:04Every time a four wheeler cuts off a U.S. Xpress truck, the truck slows down to reset the following distance.
In ballparks, at 55 mph, a 18 wheeler needs about 300' to stop, where a car stops in about 100'
If only four wheelers knew....
precopster
Manufacturers could also incorporate systems that can give you a monthly driving performance based on various factors such as exceeding zoned limits, changing lane in an aggressive fashion (higher sideward G's), changing two lanes at once and keeping safe proximity to the vehicle in front given present conditions and .
The display could give you a report and total score and graphs based on previous results. In fleets this report could be emailed to the managers and a "driving safely" or "gentlest driver" based on reasonable acceleration Gs bonus could be awarded to the highest score. No longer would we need to call trucking and transport companies to complain of drivers' behavior. Lower scores could attract a "needs improvement" alert that would stop drivers getting a "safe driver" bonus each month.
If you hit people where it hurts the most some good has to come of it.
93Regina
Post by 93Regina »
precopster wrote: 25 Apr 2019, 22:15monthly driving performance
Truck fleets have had this ability since 1990s, and maybe before....monitoring brake pedal pressure (air brakes), and RPM (downhill RPM exceeding engine spec).
93Regina
Post by 93Regina »
With this newer tech, this accident would have been prevented:
A semi plowed into cars stuck in traffic near Denver. Police say multiple people died - A runaway semi plowed into stopped traffic near Denver, igniting a fiery crash that included a dozen cars and three semis. Multiple people were killed, authorities said.
RickHaleParker
93Regina wrote: 26 Apr 2019, 06:21 With this newer tech, this accident would have been prevented:
Runways are the result of brake fade. The only technology that will arrest a runaway is runaway ramps.
93Regina
Post by 93Regina »
RickHaleParker wrote: 26 Apr 2019, 06:40Runways are the result of brake fade
It happened in Lakewood area....DOT will investigate. I do not buy the "brakes failed."
"When asked whether there were any mechanical issues with the truck, Countryman said it is something his department is looking into, but he believes even if there were a mechanical issue, vehicular manslaughter charges would still stick. "
He was not paying attention, imho.......cars stuck in a jam is nothing new in Denver area. Imho, this 23 year old driver was "high balling" with his attention focused elsewhere. He was eastbound, so sun was not a factor.
