Is this that car you were referring to when you said 'eron' on my part donation post?abscate wrote: 11 Oct 2019, 04:17 Preamble, mileage on car 239748
I thought I detected rough running for the last two week at startup and cold idle, but after 60 seconds idle was smooth, so I took no action. I did check #3 plug and found it at 0.032 with some tip wear, and meant to compare it to new, plugs have 24k on them, Volvo OEM style. Coils estimated to be 80k miles, OEM Bosch
Leaving downtown ROCHESTER, two hours after a long drive, I had a missing cylinder, low power, and bad exhaust smell. It cleared after 5 minutes of driving to my next destination. I then headed out 490 towards Buffalo, and the miss returned with a CEL.
The incident
I was able to reach my ObD in the glove box and read codes, and had two...P0352 #2 coil primary failure and #2 misfire P0302
The repair
I pulled over, T25 for cover, M6 for coil screw, spare coil from parts kit, installed and miss cleared. I will test today on the drive home.
Waze told me instead of being 15 minutes early to my next destination, I was now only 8 minutes early. I lost one minute saying hello to the guy who pulled over to help in the first 30 seconds. It’s A Buffalo thing.
Analysis
Relatively early coil failure. I will order a replacement but have to think about replacing other four coils. This same repair on the GW would suck.
1999 T5V70M56 road incident report, misfiring [ bad #2 coil]
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 1613 times
- Been thanked: 4075 times
My Enron stock ?
I have a 1998 that I need to pull the motor and trans this fall before year end. I can’t get to the motor mount parts until I get the big pieces off. I think Thanksgiving week will be earliest I can get to it.
- CIK7
Ok I see what you mean. Thank you.abscate wrote: 10 Nov 2019, 11:50 My Enron stock ?
Yes wcm got the horns that day. By kicking us back into pure diagnostic mode, we figured out the failures were unrelated
Moving the bad component moved the P030x code
The spark plugs were replaced a week after the coil failure, and ran fine for another week after
- 1750 Views
- 12 Replies
- 3568 Views
- 1368 Views
Last post by wizechatmgr
- 19 Replies
- 4636 Views
- 105 Replies
- 18961 Views
Last post by jamadams
