For breaking loose the lug bolts that require an impact wrench capable of 1050 ft lbs you better get a long stick and hit a person with it who touched the lug bolts the last time, since the required torque is only about 100 ft lbs.RickHaleParker wrote: 06 Nov 2019, 07:08 For breaking loose you need a big boy like this, 1050 ft. lbs of bolt breakaway torque. $100.00 at Harbor Freight.
My Impact Wrench Is Not Strong Enough
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
- RickHaleParker
- Been thanked: 980 times
US 110V outlets are 15 or 20 Amps.vtl wrote: 04 Nov 2019, 08:31 Because in US we have 110v. With typical 7 Amps it is only 770 Watts of peak power. Modern batteries in cordless tools allow peaks well north of 1000 Watts.
Active
Past
Past
- RickHaleParker
It takes over 100 ft. lbs to over come the inertia.
Active
Past
Past
- RickHaleParker
Me neither. I got the I got the 1050 ft. lbs to remove Axel nuts. I don't use it for much else. A 18" breaker bar usually does the job on everything else.vtl wrote: 06 Nov 2019, 07:57 Sure, the bolts do freeze, but I never had a trouble of removing the bolt once it was properly torqued.
Active
Past
Past
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
I use a metre long breaker bar and a socket for the whole job. Break loose then straighten at the pivot and just spin the bar between my fingers to get the bolts loose. Same procedure to put them back except I use a torque wrench to tighten them to 110 Nm which is about what's recommended IIRC. It's very easy to over tighten using power tools since this really isn't a very high torque.
The breaker bar is always kept in the car for roadside use. It's much easier to stow than the silly original tool since it's straight. It fits down in the rear in behind the battery and tyre.
- Been thanked: 4071 times
We use the Volvo lug nut wrench, and use our piece of pipe that we keep up front to extend the torque range.
The pipe is to bash in the heads of car jackers and take away their guns.
