If you drive in a lot of salt,
definitely check ALL positive
cables, ground straps and
their connections.
upgrade charging system?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
It is a Midwest car with extreme cold and salted road indeed. The cables are original 23+ years.
Mulling over buy or build?
Unless you say otherwise, I'll take cables off, clean and restore connectors, and reinstall.
Following device connected to lighter port was reading 13.3v during the 30-min test drive.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
No cleaning is possible because they are burnt under insulation.
They must be replaced.
Cig.lighter output will allways show less than real.
Battery terminals should be used for checking.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
I have one of those for each rig.
They aren’t a DVM on the alt output,
but they give you a quick snap shot
of the voltage from the distribution block.
And ya need to charge stuff anyway...
AFA the cabling, with heavy salt, there can
absolutely be a lot of nasty business going on
under the insulation. You can take a whack at
cleaning, but you may very well have to replace.
xHeart
You're correct Misha, the reading at battery cable while idling is 13.5-13.6v, so yes, it is higher than the reading at the cig.lighter.
Unless otherwise, ordering this item https://www.fcpeuro.com/products/volvo- ... 70-9456836
- misha
That's what you need.
But you can build your own for about 10-15$...i guess.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xHeart
Is this FcpEURO cable long enough?
There are 2 more connectors fastened on at the positive red battery connector, assuming one goes to starter.
FROM VIDA:`
Removing the existing cable terminals
Remove the splash guard over the starter motor connections.
Detach the connection at the starter motor/generator.
Cut off the cable terminals on the cable to be replaced. WHAT?
Insulate the ends of the cables with electrical insulation tape. WHAT?
FROM VIDA:`
- Has thanked: 1611 times
- Been thanked: 4075 times
The positive battery cable on these cars is buried inside the main electrical loom so you can’t really remove th sold one without major surgery. You just leave it in, and it is considered good electrical practice to insulate the ends of dead, unused wires,
Route the new one along the bus, and secure with zip ties every 10-15 cm and when it bends
xHeart
While waiting on new cable, I do not have IR gauge but my multimeter can read temperature with the specialty probe. Where to place probe for temp read?abscate wrote: 26 Dec 2019, 07:30 That’s a big drop on the B+
Do you have an IR gauge you can check the temperature of the cable after 15 minutes running with all the lights on ?
xHeart
It is known that VIDA DiCE doesn't read 1997 850 for diagnostic over OBD2, but the database matches VIN and provides Parts and Repairs under INFORMATION tab with useful instructions.
- 12 Replies
- 11513 Views
Last post by warcraftjunkie
- 3050 Views
Last post by dcarlson12
- 20 Replies
- 4091 Views
Last post by bmdubya1198
- 1119 Views
Last post by cracra
- 1315 Views
Last post by 940tvolvo
