Are they OE? I was looking at FCPEuro, theirs are over $300.azureblue wrote: 28 Jan 2020, 10:09 It is worth it to get a new one - I got mine from O'reilly and it was almost the same price as rockauto. $150 for passenger / $100 for driver side
intermittent right front vibration
weste46
- Year and Model: 2004 XC70
- Has thanked: 3 times
- Been thanked: 2 times
weste46
I went to replace my wheel bearing over the weekend and instead found axial play in the outer joint of my driver's side axle (the side that is making noise.) I don't have any clicking, but I can feel play in the axle, and no play in the wheel bearing. The noise comes and goes, I can't decide which one to replace. I can still return the wheel bearing if I replace the axle and find that it's the problem, so I think I may do that first (local axle rebuilder has one in stock for $80.)
I will update when I solve my issue...
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Axle clicking happens when the CV joint wear is really advanced. An axle with small play can cause vibrations at 50mph+ Only a very worn bearing with clear play by hand will cause vibrations. Turn the bearing by hand with the axle removed, if it feels smooth it's good
weste46
So my axle did have some axial play (in/out, not radial) but my vibration ended up becoming more and more like a normal wheel bearing failure and so I replaced the wheel bearing. It was indeed the wheel bearing. Very odd as it started off as an intermittent vibration only at low speed, but it eventually evolved into a high-speed vibration that would worsen when turning right.
- 3231 Views
- 4207 Views
- 2508 Views
Last post by benpineapple
- 2074 Views
- 1313 Views
Last post by dux02v70
