850 dash warning lights Topic is solved
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Re: 850 dash warning lights
Post by misha »
I'm not sure....but i think that there you should have battery voltage.
However....you don't have output from the alternator.Replacement should give you a proper 13.8-14.2v at idle.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
crlande wrote: 04 Feb 2020, 13:12 Hey misha! I measured 7.5 volts on the thin wire with key pos II. Not sure if that means anything. FCEuro alternator is being shipped here.
Thanks again.
Carl
Since you said that you didn't have a "Battery" light on, did you try grounding that this wire? Doing so should cause the battery(and other lights I mentioned in my post) to light. That would rule out any issues with that exciter circuit wiring.
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
OK everyone! I big thank you to misha with the knowledge and advice. After a few hours a day, after work, after brain clearing jogs, and in two days of rain, I have replaced alternator and fired her up today. No flickering dash lights. Consider this a fix! Hot damn! Thanks again misha! Nice directional guidance.
misha
Post by misha »
I'm glad that you solved the problem. ;)
Do you have proper voltage readings now on both....alternator and battery terminals?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
crlande
Has thanked: 1 time
Post by crlande »
Was too happy to check but I will go out and check right now for you! And yes it is raining again.
misha
Post by misha »
Don't bother!
Whenever you have time.
I just wanted to check that problem is gone.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
crlande
Has thanked: 1 time
Post by crlande »
Yes they look good at both!! And I don't mind the rain, love to play soccer in it. Feels better on the knees!!
misha
Post by misha »
Problem solved!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
crlande
Has thanked: 1 time
Post by crlande »
Did not even need to swap the pulley as FCP recommended. Their special tool ( $7 CTA 8089 socket) would not have worked anyway. I grabbed a free loaner pulley tool kit from local Autozone but did not need to use that either as the FCP reman Bosch alternator had the same size pulley on it as my original alternator.
