1998 S70 - No parking lights, tail lights or tag lights.
Wjncs77
Year and Model: S70, 98
Post by Wjncs77 »
I have a 1998 S70 GLT. Recently my tail lights, parking lights and tag lights do not illuminate when turning on the headlight switch. The lights do flash when locking the doors, using a turn signal or turning the hazards on. All the fuses are good, I have tried multiple headlight switches including a brand new one and also have replaced the ignition switch and the lighting relay. From what I understand of the wire diagram there is supposed to be 12 volts on fuse 23 when the head light switch is clicked one time, however I get no voltage at fuse 23. There is 12 volts coming out of the headlight switch as indicated on the schematic on #2 which is two white wires when the switch is flipped.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
See this diagram, and check page 84:
http://www.volvowiringdiagrams.com/volv ... rtible.pdf
This is the normal flow of electrical current:
- Key in position II, current flows from positive battery through the ignition switch 15A to #86 of "Overload Relay" (in engine compartment fuse box).
See GREEN dots.
- This activates the "Overload Relay", sending current from #30 to #87.
- One branch goes to "Light Switch" and another goes to "Bulb Indicator".
See BLUE dots.
- Now, if you turn on the "Light Switch", it feeds current to 24/13B, which feeds Fuses #23 and #24.
These 2 fuses #23 and #24 feed the license plate, tail lights etc.
*** To test Fuse #23 and #24 correctly:
- Key in position II.
- Fuses removed and check on both sides of the connector. It should read 12V.
- If not, the problem is upstream...either the Light Switch or the Overload Relay, which is a fancy term for a simple Bosch Relay.
HTH...
Has thanked: 1609 times
Been thanked: 4063 times
You could also have a wiring break at the rear. The wagons suffer from this, not sure about the sedans
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The sedans have the same problem but usually for a different reason.
The wiring for things on the trunk deck run through a wire loom that follows the left hand hinge / damper arm and it is easy to chop the wires if you try to close the trunk with a suitcase or a box under that hinge arm. Since it is all in the loom it is a bit tough to find but once the bad spot is found it is easy to splice them back together.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
The hazards, turn signal and alarm lights are unrelated circuits.
If you have power leaving the switch, but not getting to the fuses,
it's a pretty short trip. The connection at 24/13B, #8 or the fuse
holder contacts for locations 23 and 24 seem like the places to
look. I'd start by double checking the fuses and their contacts
in the fuse box.
