2008 XC90 Restoration from Salvage Spring/ Summer 2020
- 2000c70hpt
- Year and Model: 2000 C70
- Has thanked: 1 time
- Been thanked: 8 times
Well I got the subscription I needed for vida. Now to download the software to program the new key, and see what happens.
2000 C70 hpt with 140k
2008 xc90 t6 non turbo with 170k
- SuperHerman
- Been thanked: 207 times
Take notes of the process and keep us posted.
Sounds like the car is in good hands.
For tires make sure the load rating is not on the low end, higher better. XC90s are tire eaters.
- 2000c70hpt
It's alive!!. Runs and drives, quiet, alignment way off, but it runs great. I'll get that write up posted soon. For what it's worth, there's a new free version of vida that's works with cloned devices and windows 10 64bit laptops
- 2000c70hpt
So after new wheels and tires, I found out the subframe was bent. I kinda had a feeling it was, but I’ll get it fixed
- SuperHerman
By subframe are you talking about the unibody structure or a replaceable piece? If the latter you can by a used unit, if the former you will need a reputable shop to do the pulling. My friends in the industry love the Volvo protection designed into the unibody, but they are a difficult pull as a result. Sometimes they can be pulled without having to do major surgery, but sometimes a correct repair requires new rails and welding. Depends on what the damage is.
- 2000c70hpt
I mean the removable part. There’s an aluminum bracket that bolts to the steel with the upper control arm where it looks like the bolt tried to pull through. I’m going to take that arm off and see if I can straighten that steel it mounts to
- 2000c70hpt
Got the subframe set right, and the car was able to be aligned properly. Next is rear springs or just helpers from ipd, and the front spring mounts, and strut bearings. Found out there is also a bad connection on the fuel pressure sensor as it pops a check engine light then goes off randomly. Just have to clean the connector and see what happens. Headliner is next and passenger curtain airbag.
- Been thanked: 4068 times
Florida Volvian .can I Retitle your thread To 2008 XC90 build?
I’ve always wanted to find one like this for SWMBOs (My new bride of 35 years) next car.
- 2000c70hpt
You can if you want hun. It's going to be a long road though
Help me with a good title
“2000HptC70’s 2008Xc90 Build “
.......looks a bit too technical and might scare off the Engineers
How about
The Tampa Campa....2008XC90 restoration
How about
- 677 Views
Last post by erikv11
- 6783 Views
Last post by 850forum
- 9704 Views
Last post by xiaofei204716
- 5559 Views
Last post by matthew1
- 754 Views
Last post by FCPEURO
