2004 S60 First cold day of the year, no start issue.
nucci480
Year and Model: 2004 s60 2.4
Has thanked: 10 times
Been thanked: 2 times
Post by nucci480 »
Cranks find, I ordered a coolant temp sensor last week. Going to swap one out and see. Got the iCarsoft Auto Diagnostic Scanner VOL V2.0 for Volvo/SAAB coming in also. Motor cranks fine just doesn’t fire.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Use only genuine for the coolant sensor- even a used one, people had problems with aftermarket from new
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
oragex wrote: 25 Dec 2020, 07:32 Use only genuine for the coolant sensor- even a used one, people had problems with aftermarket from new
Do you know who makes the Volvo sensor?
rspi
Post by rspi »
Have you checked for SPARK when the car fails to start?
oragex
Post by oragex »
There is no brand on the genuine ECT. However it says Japan
nucci480
Post by nucci480 »
Have not checked for spark will do that after I get the scanner in. Tried starting again today it fired then died and would not fire again. After that, I tried swapping the fuel pump relay for a generic one and switching the two but that did not solve the issue. I'm thinking that the used PEM I purchased a few months ago was faulty. I'm going to try and swap the PEM out for a brand new one. This is the coolant temp sensor I purchased, not sure if it is OEM quality or not. Rein Automotive ELC0081 Engine Coolant Temperature Sensor https://www.amazon.com/gp/product/B077H ... UTF8&psc=1
nucci480
Post by nucci480 »
here is a quick video I made of trying to start it today. I also noticed an engine light came on. The cheap generic scan tool i have now did not pull a code though. I reset it after though.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
I'd try a shot of ether to see if the plugs are firing.
nucci480
Post by nucci480 »
Replaced the used PEM I installed 6 months ago with a brand new unit, fired up with no problems. Shut it off started again. Then just tried to start and it wouldn’t fire again.
nucci480
Post by nucci480 »
I'm showing 0 psi on the fuel rail for pressure.
