tearing out what is left of my hair, 2000 V70 XC: P0442 Topic is solved
Rocket99
Year and Model: 2000 V70 XC
Has thanked: 56 times
Post by Rocket99 »
850 LPT wrote: 19 May 2021, 13:36 Mix a Gallon of Volvo coolant and put it in the trunk. Then enjoy your trip!
The light comes on when there is still close to an inch of coolant still in the reservoir. Pleanty of time to pull over and top up.
Just make sure to open the cap very slowly to let the pressure equalize.
OKey Dokey. Just got back from a run to town. Cooant in reservoir is one inch higher than when its cold.
Oops, this looks very bad. Blue fluid in block leak test fluid looking for exhaust gasses in coolant did not turn color, remains blue ..... but there is some increased pressure in the coolant space. That aint coming from nowhere.
Has thanked: 1610 times
Been thanked: 4065 times
The coolant level fluctuates when you run. That’s normal
It should be between min and Max when cold. Don’t go over the max mark when cold
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Rocket99 wrote: 21 May 2021, 11:42 Cooant in reservoir is one inch higher than when its cold.
It is called an expansion tank and for a good reason. Things expand when they warm up and contract when they cool down.
Active
Past
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Most do, but not ice!
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
As a lifelong Minnesotan I'm going to quibble a little and say that although water does expand when it crystallizes, once frozen the ice does shrink as it gets colder.
Post by erikv11 »
Ain't about to quibble with lifelong observations. I just abhor all generalizations. ;)
I like Fora with words like abhor, picayune, and eschew; Oxford commas and full stops being the maraschino cherries on a literary Sundae.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
abscate wrote: 23 May 2021, 04:00 I like Fora with words like abhor, picayune, and eschew; Oxford commas and full stops being the maraschino cherries on a literary Sundae.
You forced me to.
What's a comma for.jpg (60.08 KiB) Viewed 712 times
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
Rocket99 wrote: 22 Mar 2021, 05:49
BEJinFbk wrote: 21 Mar 2021, 10:44 Have you considered smoke testing for your leak?
haven't got the foggiest how that works .... have heard of the "dreaded" smoke test.
Volvos are the weirdest .... absolutely. When It runnin good its a pleasure to drive. As soon as you need information, parts, to simply located a component its a fuckin nightmare. I worked on mid 80s mercedes for years, wonderful, It is totally inconceivable there would ever be a big "to so" to simply find a component. That is routine with this bizarre thing. Volvo designers after about 1998 (I hear) went nuts. WAY too many gizmos, computers, in one location for part of the model year and in another later the same year.k, different ways and differnt components (all overpriced) different electrical, arrangements locations of doing things, densiity of tubes wires routings. Its a huge joke but I got this car free and need an automatic transmission car. As soon as I no longer do need an automatic car and this one needs a major repair Its going off a cliff into the ocean
I agree that the PCV and evaporative emissions systems seem to have been altered repeatedly by designers. I have a 98 V70 non-turbo and 1999 S70 T5. The subsystems mentions are entirely different and are also different from the many How-To threads and DIY videos most of which speak to the most common models with no indication that there are variations between models and model years. Most of the posters seem to think that what they have on their particular car is universal because they have only dealt with a certain subset of P80s. The parts and service manuals are of less use than one would expect because they will show five variations of a system with no indication of which models and years employed which. Not all Volvo documentation is this troublesome. These two systems are just the worst examples.
All U.S. market models.
All running and on the road.
Tell us how you really feel...
- Volvo Spice
