Yes, until we agree on what the measurements mean we are speaking different languages.LOB wrote: 06 Jun 2021, 08:49 I think I've confused you Chuck with the term "1 ohm". My multimeter says "1" ohm when there's 100% resistance, a broken circuit and 0.00 ohm with no resistance, connecting the two multimeter probes. My pressure switch has infinite resistance between the two pins all the time, ac running or not. I will try to replace the pressure switch (will it leak refrigerant for a few seconds while I'm unscrewing it? I'd better be fast? ). Thank you Chuck and everyone else! Sorry for fooling you with my "1 ohm" statement. I thought 1 ohm ment infinite resistance as that's what my multimeter says....
With the low pressure switch out, it should read INFINITE resistance, or open circuit between the terminals.
