AC Compressor only engages when Low pressure switch is jumped Topic is solved
LOB
Year and Model: 855 GLT 2.5T
Has thanked: 10 times
Been thanked: 16 times
Post by LOB »
Summer has hit Scandinavia!!! I've got enough refrigerant in the system (45 PSI at 26 c) and the airflow is really cool while being jumped an no blinking light from the ECC panel!
Where do I go from here? I've read that there might be a faulty switch on the compressor itself that can cause this fault and that this switch is somewhat redundant and can be jumped permanently. What else can be wrong? The AC-relay? Where is it located? I've also read that you could determine what's wrong by measuring the electricity in the low pressure switch. I've got 13 volt on one of the pins (with ground on the other pin or bare metal in the engine comp.). I've read that you should have + 13 volt on both pins but that doesn't make any sense to me albeit I'm not an electrician. Can the temperature sensors malfunction? Any advice is appreciated!
dj_v70
Year and Model: v70 2003
Has thanked: 7 times
Been thanked: 23 times
Post by dj_v70 »
2 terminal switch?
PSI reading is with ac off or on?
Disconnect cable from switch and put your jumper on cable harness.
Read ohms across switch with ac off.
Read ohms across switch with ac running.
If you have a pressure gauge, also record pressure on low side port with ac both off again while on.
Report back.
LOB
Post by LOB »
Thanks a lot! Its appreciated,
47 PSI with AC on at 77 Fahrenheit (I started this with adding some butan/propan mixture into the system so maybe its slightly overfilled!?)
130-150 ? PSI AC off (120 is of the scale of the gauge)
1 ohm (100% resistance) on the switch both with the AC on and off, having the harness for the switch jumped.
Has thanked: 1609 times
Been thanked: 4064 times
That is too high on the low side for straight R134A , but I don’t know how a R134A and propane mix measures up. I think I would evacuate and charge by mass
Remember static pressure measurements don’t mean much
LOB
Post by LOB »
At 26 c or 77 F I've read that the pressure should be 40-50 PSI. Can you interpret this chart?
https://www.duracool.com/chart.html
"Dew" and "bubble" ?
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Have you not tried to replace the LP switch?
( I see no mention of doing so)
LOB
Post by LOB »
Chuck W wrote: 03 Jun 2021, 05:56 Have you not tried to replace the LP switch?
No, can that be done without re-filling the refrigerant?
Chuck W
Post by Chuck W »
LOB wrote: 03 Jun 2021, 06:30
Yes. There is a valve under the sensor that closes when the switch is removed.
dj_v70
Post by dj_v70 »
I don't see any need to replace switch, 1 ohm is the correct answer. Pressure is not low either. This should work, I am confused. Try again?
LOB
Post by LOB »
What do you think of this suggestion from another post;
"Anyhow, he pointed out that the Volvo has multiple safety relays, and it would be quite safe to bypass this relay.
It is simple, just locate the male and female relay wires at the compressor, unplug them, leave the relay in the compressor out, connect the incoming male and female.
(The problem can be checked by a more technical person by applying 12 volts to the output of the firewall mounted ac relay. If the compressor clicks on, it is the internal relay in the compressor. This was how he confirmed the issue)
Initially it did not function. By a miracle of luck, I thought perhaps there was a need to clear some computer decision, so I removed battery power and reset the system."
viewtopic.php?t=29275
But I haven't seen any firewall mounted relay. But there's a relay behind the glovebox?
