96 Volvo 850GLT: Crank No Start
Has thanked: 1505 times
Been thanked: 3818 times
Re: 96 Volvo 850GLT: Crank No Start
Crappy spark. Get new parts from FCP , about $100 all in. If you pay less than that, you end up paying $100+ cheap parts but get some ugly paperweights
“Jimmy57 deduced the the blocking cup was 180° out of alignment. Connected the ECM could not get the timing right. Connected it could get the timing right enough using the lookup tables.”
Man, I needed him on the Silver Bullet last fall. Chased the incorrectly installed blocking cup for three weeks
LanceBoyerVLVO
Year and Model: 1996 850 GLT
Post by LanceBoyerVLVO »
Alright guys, found the problem, thank you all for the help. What ended up happening was the headgasket blew with no symptoms. After a drive home from classes, the leak got pretty bad which flooded the cylinders and caused a no start. Was no oil in the coolant but there was coolant in the oil.
Any threads on replacing the headgaskets on these things?
Robert Spinner should have one in his YouTube Series.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Ouch... not the outcome we hoped for, but glad you found the issue! It's not too bad of a job at least, just take your time and keep track of everything.
