I try to encourage people to learn what correct torque feels Like. When you are stuck on the road, Ou probably won’t have a torque wrench to deal with that bad spark plug.
After you get it off, hand tighten the plug. , then a nip with a 12 inch breaker.
The m6 on the course is a light 15 Nm torque so a wrist tight touch there.
Finally those m27 Torx on the plastic cover...finger tight
Torque Education Needed
- Been thanked: 4068 times
- RickHaleParker
- Been thanked: 979 times
A new spark plug is not "torqued" you tighten it until you feel the Crush Washer crush.
Active
Past
Past
- RickHaleParker
Snug them in: Finger tighten until the crushed Crush Washer touches the bottom of the Spark Plug Well. Then ½ – ⅔ turn more with a spark plug socket and ratchet. In other words just enough to get a good seal.kallekula wrote: 20 Oct 2021, 23:01 How much do you torque the spark plug to if you're reusing a plug where the crush washer is flat?
You are not try to bolt two pieces together. Just hold the plug in the hole and get a good seal is the objective. The threads on the plug is what holds the plug in and the Crush washer seals it. There are no rotational forces ( Torque ) there to loosen the spark plug. Snug, for a good seal, is all force you need on a spark plug. Go past that and you have problems getting them out later.
Active
Past
Past
Rick has pointed out a classic case where a torque number is a bad guide for correct fitment. If you just blindly torque to a number and some carbon or crud on the spark plugs bungs up the threads, you will reach torque before the washer seats. That will get ugly fast
- RickHaleParker
On new plugs.
1. Finger tighten with a socket and extension until the Crush Washer touches the bottom of the Spark Plug Well.
2. Attach a Ratchet.
3. Hold the extension with one hand.
4. Place two finger on the end of the Ratchet ... three if you are a sissy or getting old.
5. Pull steady with your finger muscles ( do not move your arm ). You will feel pain in your fingers.
6. When the Ratchet slips a notch and the pain lessens. That is the Crush Washer crushing.
7. STOP! You are done with that plug.
Active
Past
Past
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Yes. That advice was for old V8s and iron heads. I'm much more careful now.RickHaleParker wrote: 20 Oct 2021, 18:57A new spark plug is not "torqued" you tighten it until you feel the Crush Washer crush.
- RickHaleParker
It never was carelessness and it is still not carelessness. Matter of fact it is being careful. A Torque wrench is not going to clue you when to stop. That makes the Torque wrench the careless way for Spark plugs.BlackBart wrote: 21 Oct 2021, 10:24 Yes. That advice was for old V8s and iron heads. I'm much more careful now.
Active
Past
Past
- BlackBart
Misunderstanding each other - I never used a torque wrench. The one-wrist method with some care gives you a feel for what's happening, and you can't apply much force. That's all.
- 5257 Views
Last post by RockyCasper
- 1739 Views
Last post by kosh_al
- 3560 Views
Last post by gibbi42
- 6458 Views
Last post by Oka
- 4269 Views
Last post by gnalan
