Best Way To Start A Flooded Engine 1998v70 (with slight diversion to quantum mechanics , relativity, dark matter states,
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Re: Best Way To Start A Flooded Engine 1998v70
Post by MrAl »
RickHaleParker wrote: 07 Dec 2021, 07:13
MrAl wrote: 07 Dec 2021, 07:08 Battery seems to be doing well now even after 6 days of sitting. Should last some years.
I looked up some cooling fan numbers and found some for other cars, the power of these fans could work out to as high as 50 amp. Cant find the spec for my actual car model though, yet. Harder to measure now too since the fan doesnt run anymore, or at least not when the engine is shut off.
Did you check to see if the glove box light turns off when you close the glove box. That could be draining a battery.
Hi,
No good idea. I'll check that, and check the current drain on the battery when the engine is off i have a clamp on ammeter of fairly good quality, has 3 and 3/4 digits so it can read up to a count of 9999 which means it would read 12.45 volts for example and if the current was 300 ma it would read 300.0 ma. The bulb might be 1 watt but i'll look it up, and that would read roughly 100.0 ma or something like 80.00ma (around there).
I should have done that it's quick with the hood open but didnt think of it at the time and i was going out to the store too. I may be able to find out the drain of the dash panel too if it draws more than about 10ua, always wondered what the drain was for the instrument panel in that car as it is always "on".
A little rainy out yesterday but not too bad.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
MrAl wrote: 07 Dec 2021, 07:22 No good idea. I'll check that, and check the current drain on the battery when the engine is off i have a clamp on ammeter of fairly good quality, has 3 and 3/4 digits so it can read up to a count of 9999 which means it would read 12.45 volts for example and if the current was 300 ma it would read 300.0 ma. The bulb might be 1 watt but i'll look it up, and that would read roughly 100.0 ma or something like 80.00ma (around there).
Yep. Same solution that answers the question: Does my refrigerator light turn off when I shut the door? :wink:
MrAl
Post by MrAl »
RickHaleParker wrote: 07 Dec 2021, 07:31
Yeah, measure the AC current into the refrigerator when the motor is off. If the bulb is on, a significant current will be measured. If not then if there is a timer just the timer current will show up which i bet is very small, but if we open the door and the current goes up and then close it and it goes back down, the bulb must be turning off unless there is some other device that senses the door open/closing.
I could do that with the glove box too. Open it and look for a rise in current, then close it again and look for a drop. That test should tell all.
Has thanked: 1503 times
Been thanked: 3817 times
Wait. What happens to the light molecules after the current turns off? They cant just disappear, they have to go somewhere. How do we know they arent bouncing around in there?
The speed of light is pretty slow, Measured at Harvard here.
https://www.google.com/search?client=fi ... d+of+light
Screen Shot 2021-12-08 at 9.51.17 AM.png (269.73 KiB) Viewed 360 times
RickHaleParker
abscate wrote: 08 Dec 2021, 07:47 Wait. What happens to the light molecules after the current turns off? They cant just disappear, they have to go somewhere. How do we know they arent bouncing around in there?
Photons get absorbed and converted all the time. That is how the sun heats the earth. The Photons in the refrigerator gets converted to heat and then the heat pump pumps out the heat.
Speed of light slows down in different medias. Newton proved this in his dispersion of light experiments in 1666.
Its the Universe that has a speed limit not light. Nothing can transverse Space-time faster then 299792458 m / s.
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
You can just open the glove box each morning and measure how much light falls out. Can be messy, be ready with a bucket. If there isn't any then it's escaping, the seal around the edges of the glove box door needs work.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Sometmes I worry that RIck has fallen into the sar-chasm...
RickHaleParker
abscate wrote: 08 Dec 2021, 08:22 Sometmes I worry that RIck has fallen into the sar-chasm...
Don't worry I can fly. :lol:
RickHaleParker wrote: 08 Dec 2021, 08:29
:D :D
Off topic
You have a great thread going on in the XC90 forum about CEM and PIN coding with some guys - Im trying to figure out where to link and archive that as its crosses model boundaries. VIDA isnt really right is it? I guess a link is never wrong
RickHaleParker
abscate wrote: 08 Dec 2021, 08:39 You have a great thread going on in the XC90 forum about CEM and PIN coding with some guys - Im trying to figure out where to link and archive that as its crosses model boundaries. VIDA isnt really right is it? I guess a link is never wrong
I once proposed we name the project Odin ( Open Diagnostic INterface ) and it was well received. Perhaps a new form titled Odin. Then move it there. 🤷‍♂️ We could split off topics within the Odin form instead of one massive thread.
